cisco WS-C4507R proxy arp
netone.cisco
Hi all,
we have a 4507R switch,
Cisco IOS Software, Catalyst 4500 L3 Switch Software (cat4500-ENTSERVICESK9-M), Version 12.2(25)SG4, RELEASE SOFTWARE (fc1)
and we can´t desable proxy arp. we alread tryed the command  (no ip proxy-arp) (no ip local-proxy-arp) on the interface, and we have the response:
% Unrecognized command
Could you help us please
Mauro Silva
mario_kmc
Hi Mauro,
This command only works on L3 interfaces.
  • SVI interfaces (VLAN interfaces)
  • L3 physical interfaces (with no switchport commands)
Make sure you are disabling on the L3 interface of the network where you wish to disable proxy-arp
Mario
5 Replies 5
Is your switch configured for routing?  If not, proxy arp doesn't work.  Check for the "ip routing" command in show running-config output.
Chris
mario_kmc
Hi Mauro,
Mario
Hi Mario,
thanks for your help, it´s working now.
regards
Mauro Silva
Now we want to now how to disable global?
Hi mauro,
This IOS version for the 4500 does not have a command for this.
http://www.cisco.com/en/US/docs/switches/lan/catalyst4500/12.2/25sg/command/reference/cr_toc.html
I checked 15 and it does not have also.
Mario
