Cisco1921 Cellular 0/0/0 Not Filtering ACL (out bound)
michael.lorincz
Level 4
Level 4
In the past on a 881 I've been able to NAT traffic out the Cellular 0/0/0 interface with an ACL on Cell0/0/0 permitting only NAT'd traffic and denying everything else. This was done to prevent traffic leaving cell0/0/0 with a source address other than the ISP assigned WAN IP. For some reason on the 1921 the access list is not being utilized and non-nat'd traffic is also leaving the interface which causes the link to flap since the ISP detects source address violations. Any idea on what would be causing this?
I even stripped the config down to the following but the problem persists, any advice?
ip route 0.0.0.0 0.0.0.0 Cellular0/0/0 5
interface Loopback0
 description Management Interface (do not shut)
 ip address 10.224.0.165 255.255.255.255
 ip nat inside
 ip virtual-reassembly in
ip access-list extended TEST-CELL-ACL
deny   ip any any
deny   icmp any any
interface Cellular0/0/0
ip address negotiated
ip access-group TEST-CELL-ACL out
no ip unreachables
ip nat outside
zone-member security OUTSIDE
encapsulation slip
load-interval 30
dialer in-band
dialer idle-timeout 0
dialer string ltescript
dialer watch-group 1
async mode interactive
end
SG-142-1921#ping 8.8.8.8
Sending 5, 100-byte ICMP Echos to 8.8.8.8, timeout is 2 seconds:
Success rate is 100 percent (5/5), round-trip min/avg/max = 104/110/116 ms
SG-142-1921#ping 8.8.8.8 source lo0
Packet sent with a source address of 10.224.0.165
Success rate is 0 percent (0/5)
000083: *Oct  1 20:16:48.115 UTC: %LINK-5-CHANGED: Interface Cellular0/0/0, changed state to reset
000084: *Oct  1 20:16:49.115 UTC: %LINEPROTO-5-UPDOWN: Line protocol on Interface Cellular0/0/0, changed state to down...
000085: *Oct  1 20:16:53.115 UTC: %LINK-3-UPDOWN: Interface Cellular0/0/0, changed state to down.
SG-142-1921#sh ip access-lists TEST-CELL-ACL
Extended IP access list TEST-CELL-ACL
    10 deny ip any any
    20 deny icmp any any
SG-142-1921#
Richard Burts
The issue here is that an access list applied outbound on an interface does not filter traffic that is generated by the router itself. Your access list will prevent any transit traffic (traffic sent to the router to be forwarded by the router) but will not prevent traffic generated by the router.
You have not shown us how address translation is being done. If the ISP is detecting source address violations then it suggests that there is a flaw in your address translation logic.
Rick
Rick
Hi Richard,
Thank you very much for your response. Very helpful indeed but I'm still unsure on how to resolve. Please see below for existing NAT statement and associated ACL as well as the ACL we were using on the cellular interface (the permit statement matches the static IP assigned by the provider). When I would ping a global address not listed in the POS ACL sourced by Lo0 the outbound ACL would not filter it and the link would flap.
ip nat inside source list POS interface Cellular0/0/0 overload
ip access-list extended POS
 permit ip 10.0.45.0 0.0.0.255 4.79.143.0 0.0.0.255
 permit ip 10.0.45.0 0.0.0.255 208.80.28.0 0.0.0.255
 permit ip 10.0.45.0 0.0.0.255 12.71.112.0 0.0.0.255
 permit ip 10.0.45.0 0.0.0.255 72.167.18.0 0.0.0.255
 permit ip any 12.9.235.0 0.0.0.255
 permit ip any 198.140.216.0 0.0.0.255
 permit ip any 63.91.129.0 0.0.0.255
 permit ip 10.0.45.0 0.0.0.255 host 63.241.207.105
 permit ip 10.0.45.0 0.0.0.255 host 66.43.144.238
 permit ip 10.0.45.0 0.0.0.255 host 108.241.204.225
 permit ip 10.0.45.0 0.0.0.255 host 209.36.33.43
 permit ip 10.0.45.0 0.0.0.255 host 12.132.59.7
 permit ip 10.0.45.0 0.0.0.255 host 68.178.177.2
 permit ip any host 207.67.74.163
 permit ip any host 66.196.48.162
 permit ip any host 98.124.198.1
 permit ip any host 72.32.118.67
 permit ip any host 137.200.4.16
 permit ip any host 199.173.225.5
 permit ip any host 119.173.231.136
 permit ip any host 199.173.231.136
 permit ip any host 208.31.22.249
 permit ip host 64.183.24.194 any
 permit icmp 10.0.45.0 0.0.0.255 host 8.8.8.8
 permit icmp host 10.224.0.165 host 8.8.8.8
 ip access-group FILTER-NON-NAT out
 no ip unreachables
 ip nat outside
 encapsulation slip
 load-interval 30
 dialer in-band
end
ip access-list extended FILTER-NON-NAT
 permit ip host 166.139.240.166 any
This is interesting and I have couple of comments.
- The ACL applied outbound on the cellular interface should be pretty effective in blocking transit traffic that is not translated. If the ISP is seeing source address violations then it suggests that the traffic is probably generated by the router itself rather than being transit traffic.
- I do not know how many interfaces are on the router and how many subnets it is processing for and that might have some impact on how you do the address translation and manage traffic. The only interface you have shown so far is the loopback. And the ACL for translation only permits ICMP traffic from the loopback to a specific host. I would think that you would want to permit lots more types of traffic from the loopback. In fact I do not understand why you do not just permit anything from the loopback.
- That leads me to the observation that the ACL for address translation looks a lot like the kind of access list you would use to manage traffic on an interface. I would suggest that the ACL for address translation should be more simple and more broad. I do not see why any traffic sourced from any router interface would not be translated. And frankly I would think that any transit traffic coming through an interface probably ought to be translated. If you want to control what traffic can go where then do it with an ACL on the interfaces.
Perhaps another way of looking at it is that you are translating traffic to avoid source address violations and the accompanying interface resets. So I would be motivated to be sure that anything going out the cellular interface is translated. If you want to control what traffic is allowed to go out then not translating it and letting the ISP discard it is a counter productive approach in my opinion. I think it would be better to filter and control traffic with ACL on interfaces and then translate everything that survives your interface ACL.
And you could certainly change your FILTER-NON-NAT access list from permit any destination and put your logic for selective destinations into this exit interface filter.
Rick
Rick
Thanks for setting me straight, Richard. I think you're spot on with your recommendation to filter at the local interfaces. The customer has a very locked down network and only permits a handful of hosts to access specific internet IPs (per the POS ACL). Someone suggested we use NAT to filter out the hosts but I believe your method is better.​
I made some revisions (shown below). It appears to be sound but I'm experiencing some filtering issues. To further compliate matters we are running HSRP between the primary router and a secondary router.
Tested by connecting laptop with IP 10.10.45.20 to primary 1921 router, interface is in VLAN 10. From the laptop I'm unable to ping 8.8.8.8 and I'm unable to ping 10.10.45.252 (secondary router's IP). Both of which should work based on the POS ACL applied to interface VLAN10.
