Cisco3945E with 20 T1/E1 connections?
riadhcisco
Hi everyone,
Could you please tell me if the following configuration is responding to the request of my client asking for 20 T1/E1 connections on a Secure ISR 3945E, by combining on the same router One (01) NM-8CE1T1-PRI card and Three (03) HWIC-4T1/E1 cards.
Here are the router configuration:
CISCO3945E-SEC/K9              Cisco 3945E Security Bundle w/SEC license PAK                                    1
MEM-3900-1GU2GB                1GB to 2GB DRAM Upgrade (1GB+1GB) for Cisco 3925/3945 ISR             1
MEM-CF-256U1GB                  256MB to 1GB Compact Flash Upgrade for Cisco 1900,2900,3900            1
NM-8CE1T1-PRI                      8 port channelized T1/E1 and PRI network module                            1
HWIC-4T1/E1                          4 port clear channel T1/E1 HWIC                                                         3
SM-NM-ADPTR                       Network Module Adapter for SM Slot on Cisco 2900, 3900 ISR                  1
PWR-3900-AC/2                     Cisco 3925/3945 AC Power Supply (Secondary PS)                                 1
CAB-ACE                               AC Power Cord (Europe), C13, CEE 7, 1.5M                                           2
S39EUK9-15104M                   Cisco 3925-3945 SPE IOS UNIVERSAL                                                 1
PWR-3900-AC                        Cisco 3925/3945 AC Power Supply                                                         1
3900-FANASSY                      Cisco 3925/3945 Fan Assembly (Bezel included)                                     1
C3900-SPE250/K9                  Cisco Services Performance Engine 250 for Cisco 3945 ISR                      1
ISR-CCP-EXP                         Cisco Config Pro Express on Router Flash                                               1
SL-39-IPB-K9                          IP Base License for Cisco 3925/3945                                                       1
SL-39-SEC-K9                        Security License for Cisco 3900 Series                                                     1
Thx,
RD.
paolo bevilacqua
That should be fine.
