CISCO 1941 Router ATM interface went down while applying qos
daniscisco
c1900-universalk9-mz.150-1.M4.3
Device#   PID                   SN
*0        CISCO1941/K9          FCZ1510C50V
Technology Package License Information for Module:'c1900'
Technology    Technology-package          Technology-package
              Current       Type          Next reboot
ipbase        ipbasek9      Permanent     ipbasek9
security      securityk9    Evaluation    securityk9
data          datak9        Evaluation    datak9
PANE179#sho flash
-#- --length-- -----date/time------ path
1       147468 May 03 2011 12:27:24 hwic_shdsl_sdfe4_rt_fw.bin
2     45800912 May 03 2011 12:28:06 c1900-universalk9-mz.150-1.M4.3
PANE179#sho controller SHDSL 0/0/0
Controller SHDSL 0/0/0 is UP
  Hardware is HWIC-4SHDSL, rev 2 on slot 0, hwic slot 0
  Capabilities: IMA, M-pair, 2/4 wire, Annex A, B, F & G, CPE termination
  cdb=0x3075C738, plugin=0x26F6AED0, ds=0x30735F00 base=0x10000000
  FPGA Version is REL.3.4.0, NIOSII FW:Ver 4.1, status Running
  SDC-16i HW:Rev 1.2, status UP, FW:Ver 1.2-1.1.3__57, status Running
  SDFE-4 HW:Rev 1.2, status UP, FW:Ver 1.1-1.6.1__002                 , status Running
  NIOSII Firmware image: System
  SDC16i Firmware image: System
  SDFE4  Firmware image: flash0:hwic_shdsl_sdfe4_rt_fw.bin
  Number of pairs 4, number of groups configured 1
  Ignored CLI cmds(0), Event buffer: in use(0), failed(0)
  Group (0) info:
        Type: 2-wire g.shdsl, status: UP
        Interface: ATM0/0/0, hwidb: 0x26FCC944, UTOPIA phy 0
        Configured/active num links: 1/1, bit map: 0x1/0x1
        Line termination: CPE, line mode: 2-wire, Annex-B, PMMS disabled
        Line coding: 16-TCPAM, configured/actual rate: AUTO/1280 kbps
        SHDSL wire-pair (0) is in DSL UP state
          Termination: CPE, line mode: 2-wire, Annex-B
          CONNECT state: MAIN_DATA_MODE, cond: GHS_TRANSFER, reason: ERR_NONE
          Power back off: 0dB, FE power back off: 0dB
          LoopAttn: 17dB, SnrMargin: 21dB, Status noDefect
          Current 15 minute statistics (Time Elapsed 715 seconds):
                ES: 0, SES: 0, CRC: 0, LOSWS: 0, UAS: 0
          Previous 15 minute statistics:
          Current 24 hr statistics:
          Previous 24 hr statistics:
          ATM-TC Tx: data cells: 1983, Idle/Unassigned: 2175233
          ATM-TC Rx: data cells: 913, uncorr HEC: 14, corr HEC: 0
          ATM-TC Rx: OCD: 2, LCD start: 0, LCD end: 0
  Group (1) is Not configured.
Router WAN interface went down when apply QOS on it . Kindly suggest if this is IOS issue ???
PANE179(config-pmap-c)#interface ATM0/0/0.1 point-to-point
PANE179(config-subif)#pvc 8/35
PANE179(config-if-atm-vc)#encapsulation aal5mux ip
PANE179(config-if-atm-vc)#se
PANE179(config-if-atm-vc)#service-policy ou
PANE179(config-if-atm-vc)#service-policy output COS-OUT-SHAPED
PANE179(config-if-atm-vc)#exit
paolo bevilacqua
Update IOS and try again.
