Cisco871. 2 WAN with NAT overload (2 different ISP) 1 LAN.
CyberDjinn
Hello.
I have Cisco 871 c870-advipservicesk9-mz.124-4.T4.bin
I have 2 different ISP, for example
ip1 = 10.31.0.156/22 default gateway 10.31.0.1
ip2 = 10.31.24.79/22 default gateway 10.31.24.3
and LAN 10.10.10.1 255.255.255.248
I have no any dinamic routing protocol between me and ISPs.
ISP1 is main ISP, and ISP2 is back-up.
I try to configure router that while ISP1 is reacheble - all traffic come to internet trough that ISP. if ISP2 is down, the router must switch to back-up ISP2.
is it possible?
i read that document http://www.cisco.com/en/US/tech/tk364/technologies_configuration_example09186a0080211f5c.shtml
but there's no NAT in example, but i need it on both ISP's interfaces
vpmorozov
I've absolutely same question - two ISP, reliable static routing (with tracking), but how to configure NAT?
I've the following:
ip nat inside source route-map nat-backup interface FastEthernet0/1 overload
ip nat inside source route-map nat-main interface FastEthernet0/0 overload
route-map nat-backup permit 10
match ip next-hop 22
route-map nat-main permit 10
match ip next-hop 20
But it works only if I manually clear ip nat translation table.
Is there any other solution?
How ACLs 20&22 look?
CyberDjinn
i prepare config
version 12.4
no service pad
hostname Router
boot-start-marker
boot-end-marker
no aaa new-model
resource policy
ip subnet-zero
ip cef
no ip dhcp use vrf connected
ip dhcp excluded-address 10.10.10.1
ip dhcp pool CLIENT
import all
network 10.10.10.0 255.255.255.0
default-router 10.10.10.1
domain-name transmark.ru
dns-server 10.31.0.50 10.31.0.59
lease 8
ip sla 1
icmp-echo 10.31.0.1 source-ip 10.31.0.154
ip sla schedule 1 life forever start-time now
ip sla 2
icmp-echo 10.31.24.3 source-ip 10.31.26.79
ip sla schedule 2 life forever start-time now
track 123 rtr 1 reachability
track 124 rtr 2 reachability
switchport access vlan 2
interface FastEthernet1
interface FastEthernet2
interface FastEthernet3
interface FastEthernet4
description ISP1
ip address 10.31.0.154 255.255.252.0
ip nat outside
ip virtual-reassembly
duplex auto
speed auto
interface Vlan1
description LAN
ip address 10.10.10.1 255.255.255.0
ip nat inside
ip policy route-map all-out
interface Vlan2
description ISP2
ip address 10.31.26.79 255.255.252.0
ip nat outside
ip classless
no ip http server
no ip http secure-server
ip nat inside source route-map isp1 interface FastEthernet4 overload
ip nat inside source route-map isp2 interface Vlan2 overload
access-list 101 permit ip any any
access-list 102 deny ip any 10.31.0.0 0.0.255.255
access-list 102 permit ip any any
route-map all-out permit 10
match ip address 101
set ip next-hop verify-availability 10.31.0.1 20 track 123
set ip next-hop verify-availability 10.31.24.3 30 track 124
route-map isp2 permit 10
match interface Vlan2
route-map isp1 permit 10
match interface FastEthernet4
control-plane
line con 0
no modem enable
line aux 0
line vty 0 4
scheduler max-task-time 5000
end
but i need to configure ipsec tonnel with central office. But in that case, the traffic for ipsec must be "cut" from NAT.
I cant configure that task. help please.
