CISCO881-K9
For client to site vpn on CISCO881-K9 need any license?
9 Replies 9
Gaurav Mahajan
http://www.cisco.com/c/en/us/products/collateral/routers/800-series-routers/qa_c67_458826.html
Q.    What advanced security features do the Cisco 860 and 880 Series support?
A.     With the Advanced Security feature set, Cisco 860 Series routers support basic security features such as site-to-site VPN, Easy VPN, and application inspection and control with Cisco IOS Firewall. With the Advanced IP Services feature set, the Cisco 880 Series routers also support advanced security features such as DMVPN, Group Encrypted Transport VPN, IPS, and subscription-based content filtering.
The licenses on the 881 are already shown. But client to site VPNs (or RA-VPNs) come in different flavors. For the legacy EasyVPN you don't need any additional license. But if you want to use AnyConnect, you need to license this client in addition to having a VPN gateway.
what is the license please ?
There are different options. You are most likely looking for an AnyConnect Plus Subscription:
AnyConnect Ordering Guide
Any connect Plus it can be used on 881 router?
From the ordering guide:
2.1 Servers and Platforms
AnyConnect services are used in conjunction with numerous Cisco head server platforms, including but not limited to the Cisco Adaptive Security Appliance (physical and virtual), Cisco FirepowerTM Next-Generation Firewalls, Identity Services Engine, Aggregation Services Routers, Cloud Web Security, and Cisco IOS® Software on
Cisco Integrated Services Routers. Headend termination devices and cloud services, along with the associated service costs and support contracts, are purchased separately.
Thaaanks alot the last thing i need know how many client to site vpn connection i can do with 881 ?
To my knowledge, only the maximum IPsec tunnels are documented (which are 20). I'm not 100% sure on this, but I think the amount of SSL/TLS-VPN peers is the same.
