Clarification needed on upgrading IOS image on stack switches (3750)
mhabeeb_ahmed
I am upgrading new IOS image on a stack switches of 9 (3750G-48TS) for enabling faeture of SSH as it is currently lacking SSH login feature. I came across through cisco documentation that I can upgrade the new IOS image on all 9 switchs of a stack with a single command. Below is the link for your reference:
http://www.cisco.com/en/US/products/hw/switches/ps5023/products_configuration_example09186a00804799d7.shtml#cfbin1
Right now all switches have the new IOS k9 image copied. Attached file you will find the switch details with current and new IOS image for your reference:
I have a doubt like, if i proceed with the above cisco documentation on step 4 as "boot system switch all flash:/
c3750-advipservicesk9-mz.122-52-SE.bin
Switch(config)#exit
Switch#write memory
will it boot with the new IOS image on all member switches or on only master switch will reboot with the new IOS.
Kindly share the expereinces with a similar situation realted to the stack 3750G-48TS switches.
Much appreciating your response
Mohammed
13 Replies 13
Asad Raza
Level 4
Level 4
If you reload the master then whole stack will reload and boot up with the new image. You can also try reloading one member switch at a time by using  'reload slot stack-member-number'
Thanks for your reply.
I'll try this as well for an alternative.
Mohammed
Leo Laohoo
Sure you can.  But it's a heart-stopping experience when the switch of this huge stack because it will "pause".  The command is "arch download-sw /dest 1 /dest 2 /dest 3" ...
I never use this command unless I have more than one IOS in a switch.  The 3750G-12S, for example, does not have enough flash space for two full IOS.
I tried as per cisco documentation but it is failing
on member switches. Can anyone quickly update me on this becuase my downtime of
changemanagment is of 1 hr from now.
below is the error I am getting:
s1-401(config)#boot system switch all c3750-ipbasek9-mz.122-52.SE.bin
%Command to set boot system switch all c3750-ipbasek9-mz.122-52.SE.bin on switch=2 failed
%Command to set boot system switch all c3750-ipbasek9-mz.122-52.SE.bin on switch=3 failed
%Command to set boot system switch all c3750-ipbasek9-mz.122-52.SE.bin on switch=4 failed
%Command to set boot system switch all c3750-ipbasek9-mz.122-52.SE.bin on switch=5 failed
%Command to set boot system switch all c3750-ipbasek9-mz.122-52.SE.bin on switch=6 failed
%Command to set boot system switch all c3750-ipbasek9-mz.122-52.SE.bin on switch=7 failed
%Command to set boot system switch all c3750-ipbasek9-mz.122-52.SE.bin on switch=8 failed
%Command to set boot system switch all c3750-ipbasek9-mz.122-52.SE.bin on switch=9 failed
what to do next from here?
I even tried individually but still the result is same:
hqans1-401(config)#boot system switch 2 c3750-ipbasek9-mz.122-52.SE.bin
%Command to set boot system switch 2 c3750-ipbasek9-mz.122-52.SE.bin on switch=2 failed
How many IOS do you have in your switch?  If you have only one, then disregard this.
We have two IOS image on the switches as depicted below:
s1-401#sh flash
Directory of flash:/
    2  -rwx       61573   Dec 5 2009 11:54:43 -08:00  hqans1config
    3  -rwx       60521  Aug 19 2010 17:16:05 -07:00  config.text
    4  -rwx        1224  Jul 16 2010 16:58:22 -07:00  vlan.dat
    5  -rwx       21528  Aug 19 2010 17:16:06 -07:00  multiple-fs
    6  drwx         192  Feb 28 1993 16:09:15 -08:00  c3750-ipbase-mz.122-25.SEE3
  459  -rwx          27  Aug 19 2010 17:16:05 -07:00  private-config.text
  460  -rwx    11110304  Jul 13 2010 10:19:50 -07:00  c3750-ipbasek9-mz.122-52.SE
  461  -rwx    11110304  Jul 13 2010 10:59:40 -07:00  flash3
32514048 bytes total (1355264 bytes free)
s1-401#sh flash2
Directory of flash2:/
    2  -rwx       60521  Aug 19 2010 17:16:08 -07:00  config.text
    3  -rwx          27  Aug 19 2010 17:16:08 -07:00  private-config.text
    5  -rwx       21528  Feb 28 1993 16:56:57 -08:00  multiple-fs
    6  drwx         192  Feb 28 1993 16:09:40 -08:00  c3750-ipbase-mz.122-25.SEE3
  459  -rwx    11110304  Jul 13 2010 10:27:43 -07:00  c3750-ipbasek9-mz.122-52.SE
32514048 bytes total (12527616 bytes free)
s1-401#sh flash3
Directory of flash3:/
    5  drwx         192  Feb 28 1993 16:08:59 -08:00  c3750-ipbase-mz.122-25.SEE3
  458  -rwx       21528  Feb 28 1993 16:56:57 -08:00  multiple-fs
  459  -rwx    11110304  Jul 13 2010 11:06:02 -07:00  c3750-ipbasek9-mz.122-52.SE
anyone can let me know what next to be done with the other stack switches (2-9)??/
Do you still need 12.2(25)SEE3?  If not, delete the file and subdirectory using the command "delete /f /r flash1:c3750-ipbase-mz.122-25.SEE3" and so on.
I see some problem here
I reload the stack ..........
hqans1-401#sh switch deta
                                               Current
Switch#  Role      Mac Address     Priority     State
1       Member    001c.b0aa.d000     15        Ready
*2       Master    001c.0fe2.5400     1         Ready
3       Member    001c.b135.4600     1         Ready
4       Member    001c.5721.df80     1         Ready
5       Member    0000.0000.0000     0         Provisioned
6       Member    001c.0fe2.5d80     1         Ready
7       Member    001c.5721.de00     1         Ready
8       Member    001c.0fe2.6480     1         Ready
9       Member    001c.b149.7400     1         Ready
         Stack Port Status             Neighbors
Switch#  Port 1     Port 2           Port 1   Port 2
  1        Ok         Ok                2        9
  2        Ok         Ok                3        1
  3        Ok         Ok                4        2
  4       Down        Ok              None       3
  6        Ok        Down               7      None
  7        Ok         Ok                8        6
  8        Ok         Ok                9        7
  9        Ok         Ok                1        8
Looks like you need someone to eyeball the switch.
... OR maybe it may just take a little while because you are upgrading from 12.2(25) to 12.2(52) which requires the new IOS to upgrade the Bootstrap and require to boot TWICE.
might be i have to check. As of now i have rollback on the old ios image and the switches are running normal. I need to figure it out tommorow morning.
One way in my mind is that I can break the stack and give the boot variable on individual 9 switches. But I think there is also a way that we can upgrade
IOS and can have the boot variable on the stack switches without breaking stack.
Any help would be appreciated in this regard.
regards,
Mohammed
