Clarification on txload and rxload on serial port for routers
Hi all,
I have a 1905 series cisco router, when I run "sh int" command it gives me following details -
MTU 1500 bytes, BW 1544 Kbit/sec, DLY 20000 usec,
     reliability 254/255, txload 7/255, rxload 151/255
  Encapsulation PPP, LCP Open
  Stopped: CDPCP
  Open: IPCP, loopback not set
  Keepalive set (10 sec)
  Last input 00:00:00, output 00:00:00, output hang never
  Last clearing of "show interface" counters 1d21h
  Input queue: 0/75/0/0 (size/max/drops/flushes); Total output drops: 17
  Queueing strategy: fifo
  Output queue: 0/40 (size/max)
  5 minute input rate 918000 bits/sec, 85 packets/sec
  5 minute output rate 45000 bits/sec, 61 packets/sec
     1953638 packets input, 1981536818 bytes, 0 no buffer
     Received 0 broadcasts, 3623874 runts, 0 giants, 0 throttles
     10385026 input errors, 6753254 CRC, 0 frame, 0 overrun, 0 ignored, 7898 abo
Please let me know the significance of txload and rxload.
This router is used for MPLS connectivity.Link is working OK..but I'm not able to understand
exactly what is the above txload and rxload signify.
There is also one peculiar phenomena occuring, when my reliability goes down then rxload also goes down or might be vise versa.
Please tell about this.
Mahendra
Giuseppe Larosa
Hello Mahendra,
the txload and rxload are an alternate way to express the sent and received traffic rates.
The rtxload and rxload are percentages expressed in fractions with a 255 denominator so in you case you have:
rxload 151/255 to be referred to link speed 1544 kbps =
914,29 kbps
and you see
tx load 7/255 again to be referred to link speed 1544 kbps = 42,38 Kbps
this is another way to say:
5 minute output rate 45000 bits/sec, 61 packets/sec =
As you see the numbers are very close.
The reliability percentage is expressed in terms of a fraction with denominator 255 and 254/255 means that the link is not totally stable .
The percentage expresses the uptime of the link / total time as  successfully received keepalives / total keepalives messages.
When reliability goes down, it is because the OSI layer 2 keepalives have failed for a short time the link has been declared down (IPCP closed, NCP closed), routing protocol may flap, and as a result of this the traffic on the link goes to zero after the fault is detected.
For this reason you see some correlation between downs on reliability and lowering of rxload because they are related.
I would not say the link is clean unless you have plugged / unplugged the cable in the last two days.
For further troubleshooting you can follow this troubleshooting guide
http://www.cisco.com/en/US/docs/internetworking/troubleshooting/guide/tr1915.html
Hope to help
Giuseppe
Joseph W. Doherty
Disclaimer
The  Author of this posting offers the information contained within this  posting without consideration and with the reader's understanding that  there's no implied or expressed suitability or fitness for any purpose.  Information provided is for informational purposes only and should not  be construed as rendering professional advice of any kind. Usage of this  posting's information is solely at reader's own risk.
Liability Disclaimer
In  no event shall Author be liable for any damages whatsoever (including,  without limitation, damages for loss of use, data or profit) arising out  of the use or inability to use the posting's information even if Author  has been advised of the possibility of such damage.
Posting
Your counters for input errors, CRC errors and aborts are also indicative of link with some quality issues.
