ASR IOS Degrade
smartboy2255
Hi All,
I want to degrade ASR IOS from asr1000rp2-advipservicesk9.03.04.02.S.151-3.S2.bin to asr1000rp2-advipservicesk9.02.04.02.122-33.XND2.Its a non production router.While I am doing ISSU steps I am getting below error.
--- Starting image verification ---
Compatibility check with running software on active RP
FAILED: Package(cc_spa) version(02.04.02.122-33.XND2)
FAILED: in candidate software set does not meet 'must-not-match(^02.0[0-6].*)'
FAILED: specified in running software set.
Software sets are not identified as compatible
  FAILED: External compatibility check failed
What is the easy step to degrade the IOS.Since its a non production router thre is no issue of downtime.
New IOS : asr1000rp2-advipservicesk9.02.04.02.122-33.XND2
AVS
Do you check if the ios you are trying to install is supported by the supervisor?
Sent from Cisco Technical Support Android App
