03-09-2011 12:33 AM - edited 03-04-2019 11:41 AM
hello,
I set globally the QOS on my infrastructure and I want to monitor graphically the usage of each classes.
I'd like to do that on my COREs Switchs which are Catalyst C6509.
I can achieve that in command line, but it's not user friendly and it's not possible to have daily/hourly graphs.
So the idea is to find the value in the MIBS and put it in MRTG graphs.
The only problem is that I cannot find it in the MIBS.
Is someone has an idea?
Kind regards
Gildas
03-09-2011 08:02 AM
6500 supports the CISCO-CLASS-BASED-QOS-MIB. I think you should take a look at polling it to get the required information. Additional MIB information is at:
http://tools.cisco.com/Support/SNMP/do/BrowseMIB.do?local=en&mibName=CISCO-CLASS-BASED-QOS-MIB
Atif
03-10-2011 12:01 AM
Thanks Atif for the information, but have you got any idea about the OID, because in the MIBs it's hard to find the good entries.
GIldas
