Class C v/s Class B Addressing in a small switched network
ravi.malghan
Hi: I have a small network with about 3 edge switches and a core switch. About 100 users and one single VLAN. I am about to create a 3 separate VLANs. I have a few questions about IP Addressing.
Since I donot have any routers, does it matter if I use a Class C or Class B address? In other words I am trying to see if performance might be different if I use a subnet mask of 255.255.255.0 vs using 255.255.0.0 for all devices in the network.
Ravi
Marvin Rhoads
It will make no difference with respect to performance per se. Assuming you're using RFC 1918 address ranges, use a Class A space it you'd like (10.x.x.x).
It would however behoove you for purpposes of address management to mask whatever network number you use down to an appropriate managable range - probably a /24 or /24 for a network that size.
Hope this helps. Please rate helpful posts.
ekiriakos
You said that you don't have any routers. If you want inter-vlan communication you need a router.
Rgds
E.
Most switches characterized as "core" switches these days run IOS and have routing functionality built in.
Ravi - switch model and image name will tell us that ("sh ver" output).
