Class-Default bandwidth question
reinier.hamstra
Hi all,
Can someone point me to another source of documentation that confirms the actual bandwidth allocated to the Class-Default when no specific Bandwidth Percent command is given?
policy-map scheduler-lmc
class prec5
priority percent 10
class prec3
bandwidth percent 50
class class-default
fair-queue
Link Bandwidth: 4000
Link type: Ethernet
max-reserved-bandwidth is Default: 75%
Question: What percentage of link BW is allocated to the Class-Default?
My own argument would be:
75% (max-reserved-bandwidth) -/- 60 %(LLQ + 2nd Q) = 15%
I follow this reasoning because when I attempt to configure the Class-Default with the Bandwidth Percent command, I am only allowed to configure 15%.
HOWEVER: According to the infromation provided in the link below: Class-Default takes it?s bandwidth from the percentage that is not available for allocation to configured classes, read: 25% (100% of link BW -/- 75% max-reserved-bandwidth).
http://www.cisco.com/univercd/cc/td/doc/product/software/ios122/122cgcr/fqos_c/fqcprt2/qcfconmg.htm#wp1003189
mheusinger
Level 10
Level 10
First please understand, queueing config is only applied, if congestion exists. So class-default traffic could take 100% of your interface bandwidth, IF no other traffic is present.
Second, in most cases there is also traffic not accounted for in the class-maps, f.e. L2 keepalives, system packets, CDP, and so on. The router will prioritize some of this traffic. Therefore allocating 100% to user traffic is not feasible and thus the (conservative) approach with 75% of interface bandwidth.
Per se it is therefore also not simple to say X% of traffic is allocated to class-default.
By the way, the QoS 2.2 class covers this in detail.
Regards, Martin
