Class-map used by two policies input and output in the same router & interface
alison.hou
Please see partial configs.
!for both inbound and outbound
class-map match-any Voice
match ip dscp ef
!for inbount policy
policy-map INBOUND
class Voice
   priority percent 40
   set dscp ef
class class-default
   fair-queue!
! for outbound policy
policy-map OUTBOUND
  class Voice
    priority 1000
  class class-default
   fair-queue
interface atm1/IMA0
Service-policy output OUTBOUND
Service-policy input INBOUND
Can this work?
thanks,
Alison
Joseph W. Doherty
Disclaimer
The Author of this posting offers the information contained within this posting without consideration and with the reader's understanding that there's no implied or expressed suitability or fitness for any purpose. Information provided is for informational purposes only and should not be construed as rendering professional advice of any kind. Usage of this posting's information is solely at reader's own risk.
Liability Disclaimer
In no event shall Author be liable for any damages whatsoever (including, without limitation, damages for loss of use, data or profit) arising out of the use or inability to use the posting's information even if Author has been advised of the possibility of such damage.
Posting
Yes (to your post's header question) and no (to your post's content).
You can use the same class-map in both IN and OUT CBWFQ policies, as they generally just match packets.  (Although you're not doing so in your posted config, don't forget when matching, and using ACLs, source and destination reverse for IN and OUT.)
You can use some of the same policy map class statements, for both IN and OUT, but in your IN policy you're using class statements (queuing) that are limited to just OUT policies.
