clear policy-map counter
josephschung
May I know which command will help me to clear the counters from output such as below? Many thanks!
   dscp    Transmitted      Random drop      Tail drop    Minimum Maximum  Mark
           pkts/bytes       pkts/bytes       pkts/bytes    thresh  thresh  prob
   af11       0/0               0/0              0/0           32      40  1/10
   af12       0/0               0/0              0/0           28      40  1/10
   af13       0/0               0/0              0/0           24      40  1/10
   af21       0/0               0/0              0/0           32      40  1/10
   af22       0/0               0/0              0/0           28      40  1/10
   af23       0/0               0/0              0/0           24      40  1/10
   af31 27096785/22398312630   1658/2181179     1757/2322604    100    1000  1/20
   af32       0/0               0/0              0/0           28      40  1/10
   af33       0/0               0/0              0/0           24      40  1/10
   af41       0/0               0/0              0/0           32      40  1/10
   af42       0/0               0/0              0/0           28      40  1/10
   af43       0/0               0/0              0/0           24      40  1/10
    cs1       0/0               0/0              0/0           22      40  1/10
    cs2       0/0               0/0              0/0           24      40  1/10
    cs3       0/0               0/0              0/0           26      40  1/10
    cs4       0/0               0/0              0/0           28      40  1/10
    cs5       0/0               0/0              0/0           30      40  1/10
    cs6       0/0               0/0              0/0           32      40  1/10
    cs7       0/0               0/0              0/0           34      40  1/10
     ef       0/0               0/0              0/0           36      40  1/10
   rsvp       0/0               0/0              0/0           36      40  1/10
default       0/0               0/0              0/0           20     40  1/10
2 Accepted Solutions
Edison Ortiz
What platform?
clear counter [interface] or just clear counters should do it.
I'm assuming it didn't work for you?
Nope, there isn't...
Edison Ortiz
What platform?
Hi Edison,
It works but together it clear all counters on the interface. Is there a specific way to clear the policy-map counters only?
We are on 7200 platform.
Thanks!
