clearing static nat entry
message4mayank
Community Member
If I have to roll back below config :-
ip nat outside source static x.x.x.x  y.y.y.y
Then do I need to first use clear ip nat outside/inside x.x.x.x y.y.y.y>>removing  existing translations for those particular IPs
and then use no ip nat outside source static x.x.x.x  y.y.y.y ?
whether clear ip nat outside x.x.x.x y.y.y.y could be run smoothly  without disturbing other translations?
Mayank
Nagendra Kumar Nainar
You dont need to clear the translations. When you try to remove the NAT command, it will pop a prompt to clear the state entries related to the removed NAT command.
-Nagendra
