Clients unable to browse the internet on Cisco 871 K9 Router
tosino489
Hi Everyone,
i just purchased my Cisco Router 871 K9 Version running this System image flash:c870-advsecurityk9-mz.124-4.T8.bin"
I am trying to configure this Router for Home use so that i can block some Web traffic (Porn sites, Movie sites because of Children) but i realised i was unable to apply the Access list Match-class version url (http host).
My major problem is even the basic config on the router. The WAN has a DHCP IP assignment with Network 192.168.1.0
The Lan is expected to have 192.168.3.0 Network. The IPs appears to be correctly assigned but not able to ping the internet on the Router. Local client also cannot resolve DNS. here is my cofig file.
Please assist.
Richard#sh run
Building configuration...
Current configuration : 1727 bytes
version 12.4
no service pad
hostname Richard
boot-start-marker
boot-end-marker
no aaa new-model
resource policy
ip subnet-zero
ip cef
no ip dhcp use vrf connected
ip dhcp pool Richard-Pool
import all
network 192.168.3.0 255.255.255.0
default-router 192.168.3.1
domain-name richardedet.com
dns-server 192.168.1.1
lease 0 2
interface FastEthernet0
spanning-tree portfast
interface FastEthernet1
interface FastEthernet2
interface FastEthernet3
interface FastEthernet4
ip address dhcp
ip verify unicast source reachable-via rx allow-default 100
no ip redirects
no ip unreachables
no ip proxy-arp
ip nat outside
ip virtual-reassembly
speed auto
full-duplex
interface Vlan1
description Local Network VLAN
ip address 192.168.3.1 255.255.255.0
ip classless
ip route 0.0.0.0 0.0.0.0 FastEthernet4
ip route 192.168.3.0 255.255.255.0 FastEthernet4
no ip http server
no ip http secure-server
ip nat inside source list 101 interface FastEthernet4 overload
ip nat inside source route-map RMAP-NAT interface FastEthernet4 overload
ip dns server
logging trap debugging
logging facility local2
access-list 100 permit udp any any eq bootpc
access-list 100 permit tcp any any
access-list 100 permit icmp any any
access-list 101 permit ip 192.168.3.0 0.0.0.255 any
control-plane
line con 0
password richard
login
no modem enable
transport output telnet
line aux 0
password richard
login
line vty 0 3
password richard
login
transport input ssh
line vty 4
password richard
login
scheduler max-task-time 5000
end
2 Accepted Solutions
problem is that you changed IP address of VLAN 1 interface from 192.168.1.254 to 192.168.1.1
So you must change default-router in dhcp pool:
enableconf t
ip dhcp pool Richard-Edet
no default-router
default-router 192.168.1.1
end
Also NAT is missing:
enable
conf t
ip access-list standard NAT
permit 192.168.1.0 0.0.0.255
exit
ip nat inside source list NAT interface Fa4 overload
end
Also maybe you cannot ping PC from console of router because firewall of computer blocks ICMP protocol. In windows I am sure that it is blocked by firewall. So you can try ping 192.168.1.1 from PC and it should work.
Try above changes and then write me if it work, or then we can make another changes.
You can also post output of commands (if it will not work):
router: show ip route
router: ping 8.8.8.8 (this should work if your internet provider doesn´t block ICMP protocol)
PC: ipconfig/all
ip address dhcp
i
ip nat outside
interface Vlan1
IP nat inside
ip route 0.0.0.0 0.0.0.0 FastEthernet4 DHCP
Masoud
15 Replies 15
Milos Megis
Level 3
Level 3
at first I don´t see command "ip nat inside" on Vlan1 interface.
Next:
command "ip route 192.168.3.0 255.255.255.0 FastEthernet4" is wrong, because network 192.168.3.0/24 is directly connected to interface Vlan1 - remove it
(but this shouldn´t affect routing table because AD of directly conected network is 1 and static route has AD=5)
command "ip nat inside source route-map RMAP-NAT interface FastEthernet4 overload" is unnecessary, because you don´t have defined route-map RMAP-NAT and implicit behaviour is deny.
And also I am not sure if interfaces Fa1 - 4 is routed or switched.
If you want to add them IP address try type command no switchport.
If it is not possible, then put them into different vlans and create VLAN interfaces for each vlan to ensure routing.
Hi Milos Megis,
Thank you so much. I will make your mentioned adjustment and revert shortly.
The Fa0-Fa3 are switch Ports and do not accept a direct IP configured on them except mapping an interface Vlan on them.
Thanks again
And also you have disabled ARP-Proxy so probably default route will not work.
Try use "ip route 0.0.0.0 0.0.0.0 Fa4 next_hop_ip_address"
or just remove default route and you should get it from ISP´s DHCP server (check it with show ip route command)
Hi Milos,
Sorry i did not respond all these while. I have included the line as you advised but still not working.
The Router did not accept "next_hop_ip_address" but does accept uptil this line "ip route 0.0.0.0 0.0.0.0 Fa4"
When i played around with the Config, i am able to ping the internet and but unable to ping the Local Computer connected via the Fa0-fa3. They are also unable to get access to the internet
Here is the WAN IP from my IPS Modem 192.168.3.0/24 (A small router)
DNS Servers 197.255.160.101 and 197.242.125.200
My Lan is 192.168.1.0. My Fa4 got 192.168.3.9 DHCP from the ISP router.
My present Config is below. I am unable to ping both Internet and intranet with my present Config but DNS is resolving when i send a Ping
hostname Router
boot-start-marker
boot-end-marker
no aaa new-model
ip subnet-zero
ip cef
ip ips po max-events 100
no ftp-server write-enable
switchport access Vlan 1
no shutdown
no shutdown
no shutdown
no shutdown
ip address dhcp
no ip redirects
no ip unreachables
no ip proxy-arp
ip nat outside
speed auto
full-duplex
no shut
import all
network 192.168.1.0 255.255.255.0
dns-server 192.168.3.1 197.255.160.101 197.242.125.200
ip domain name richardedet.com
interface Vlan1
ip address 192.168.1.254 255.255.255.0
ip nat inside
ip classless
ip forward-protocol nd
no ip http server
Router rip
version 2
network 192.168.3.1
network 192.168.1.1
no auto-summary
ip name-server 197.242.125.200
ip name-server 197.255.160.101
interface Loopback 0
ip address 192.168.3.9 255.255.255.0
ip nat outside
control-plane
Hi tosino489,
I hope that you didn´t write exactly "next_hop_ip_address" in command :-)
It must be classic IP address.
It can be most probably 192.168.3.1 or 192.168.3.254.
You can get this information, if you connect PC directly to cable instead of router and then run command line and write command "ipconfig".
In long list you will see line with text "Default Gateway.........IP_address".
This IP address you must write into command "ip route 0.0.0.0 0.0.0.0 Fa4 ip_address"
And also try do following changes in config:
Do not filter traffic until you have working configuration - so remove following command from Fa4 interface:
no ip verify unicast source reachable-via rx allow-default 100
You don´t need loopback interface (and not with this IP address - this address must be on Fa4 interface according to your description above) - so type commands:
enable
conf t
no interface Loobback 0
You don´t need RIP routing protocol because your provider probably doesn´t run routing protocol to you - so type commands:
enable
conf t
no router rip
You have wrong DHCP pool with actual configuration - so type:
enable
conf t
no ip dhcp pool Richard-Edet
network 192.168.1.0 /24
default-router 192.168.1.254
dns-server 197.255.160.101 197.242.125.200
exit
Try type command:
switchport mode access
on Fa0 - Fa3 interfaces
But most important:
enable
conf t
no ip route 0.0.0.0 0.0.0.0 Fa4
ip route 0.0.0.0 0.0.0.0 Fa4 ip_address_as_described_above
When you make these changes send me your configuration and we can try make another changes if it will not work.
Hi Milos,
Thanks a lot for your assistance. I have made the corrections and the i am able ping the internet. The only challenge at the moment is that, the Computer Plugged on fa1 does have IP/DNS but does not have internet access. I am unable to ping the IP of the Computer from the Console.
Below is the Present Config on the router.
Router#sh run
Current configuration : 1229 bytes
version 12.4
no service pad
hostname Router
boot-start-marker
boot-end-marker
no aaa new-model
resource policy
ip subnet-zero
ip cef
dns-server 197.255.160.101 197.242.125.200 192.168.2.1
ip address dhcp
ip nat outside
duplex auto
speed auto
interface Vlan1
ip nat inside
ip classless
ip route 0.0.0.0 0.0.0.0 FastEthernet4 192.168.2.1
no ip http server
control-plane
line con 0
password richard
login
no modem enable
line aux 0
password richard
login
line vty 0 3
password richard
login
transport input ssh
line vty 4
password richard
login
end
Router#sh ip int br
FastEthernet0 unassigned YES unset up down
FastEthernet1 unassigned YES unset up up
FastEthernet2 unassigned YES unset up down
FastEthernet3 unassigned YES unset up down
FastEthernet4 192.168.2.6 YES DHCP up up
Vlan1 192.168.1.1 YES NVRAM up up
NVI0 unassigned YES unset up up
Router#
enableconf t
no default-router
end
enable
conf t
exit
end
PC: ipconfig/all
Thank you so much Milos,
I appreciate your time and resourced efforts. Thanks a lot.
Here is the working config. I am able to browse on the Lan and Pings are vise versa.
Router#sh run
Current configuration : 1355 bytes
version 12.4
no service pad
hostname Router
boot-start-marker
boot-end-marker
no aaa new-model
resource policy
ip subnet-zero
ip cef
ip address dhcp
ip nat outside
duplex auto
speed auto
interface Vlan1
ip nat inside
ip classless
ip route 0.0.0.0 0.0.0.0 FastEthernet4 dhcp
no ip http server
control-plane
line con 0
password richard
login
no modem enable
line aux 0
password richard
login
line vty 0 3
password richard
login
transport input ssh
line vty 4
password richard
login
end
Router#
you´re welcome :-)
ip address dhcp
i
ip nat outside
interface Vlan1
IP nat inside
Masoud
Thanks Masoud. Your input was remarkable.
I appreciate your effort. Thanks a lot.
it is working now. I posted the Working config down below.
Thanks again!
Your are most welcome. Happy to help.
Masoud
Hi Masoud / Milos,
One last thing please. So sorry to bother you on the same topic again.
The Computers on the LAN are unable to communicate. I am unable to reach the clients connected to fa0-fa3 from the Console, neither can the clients communicate with one another.
The Clients ont the Lan can ping the Gateway and can also reach the internet.
Do have an idea on what line of command that can resolve this?
If you don't change anything in config, then it will be probably caused by enabled firewall on PCs. Do you use windows?
If yes then try to turn off FW.
