Configuring cisco 861 router for internet usinf static ip address
Hi..
I am having a cisco 861 series router.
The Cable from the isp was connected to fastethernet4(wan port)
Following are my isp details
IP address:172.16.62.130
subnet:255.255.0.0
default gate way:172.16.62.1
dns primary:202.153.32.2
secondary:202.153.32.3
How do i configure this details in the router and access the internet in my devices.
i want the network to be in 192.168.1.0 to 254.
plz let me know how do i configure my router with this details using cisco configuration professional
Bilal Nawaz
Hello, I haven't seen cisco configuration professional but since its gui based I'm sure you could find your way around or go through a setup procedure? Here is a tutorial i found which may help - the wizard should be able to take you through the whole setup.
http://www.cisco.com/en/US/products/ps9422/products_configuration_example09186a0080b2f103.shtml
Anyway - just incase you are interested in CLI...
There might be a couple of things you have missed here, like DHCP for your LAN and NAT for outbound traffic. So I will assume you need this in the configuration below
If this is a static address assigned by your ISP then you can do this:
ip name-server 202.153.32.2
ip name-server 202.153.32.3
interface fa4
ip address 172.16.26.130 255.255.0.0
no shut
ip route 0.0.0.0 0.0.0.0 172.16.62.1
If you want to configure your LAN for example on fa1 you can do this:
interface fa1
no shut
To configure DHCP for your clients to connect you can do this:
ip dhcp pool INSIDE
network 192.168.1.0 255.255.255.0
default-router 192.168.1.1
dns-server 202.153.32.2 202.153.32.3
To configure NAT using PAT (port address translation you can do this)
access-list 1 permit 192.168.1.0 0.0.0.255
ip nat inside source list 1 interface fa4 overload
interface fa1
description INSIDE
ip nat inside
interface fa4
description OUTSIDE
ip nat outside
Hope this helps
Please rate useful posts and remember to mark any solved questions as answered. Thank you.
Please rate useful posts & remember to mark any solved questions as answered. Thank you.
Bilal Nawaz
interface fa4
no shut
interface fa1
no shut
ip dhcp pool INSIDE
interface fa1
description INSIDE
ip nat inside
interface fa4
description OUTSIDE
ip nat outside
Hope this helps
SUjith_k10
   I am having a similar issue. The wan IP of the ISP is 111.93.***.*** /30. The gateway is 111.93.***.***. There are are six usable LAN ips starting from 111.93.245.144/29. The primary DNS is 103.8.46.5 and the secondary DNS is 103.8.44.5. I have configured the WAN ip on the WAN port FE 4. But when I tried to configure one of the lan ips on FE 0 port. it says IP address cannot be configured on the Fast ethernet switch ports. So I created a Vlan and assigned that Vlan to FE 0. After that I connecte that port to the pc, But the internet is not up. Please help to fnish this configuration. the LAN ips are required for me for various applications.
