Clock is unsynchronized, stratum 16, no reference clock
I have a cisco 9200 switch which is not syncing to NTP server (Linux based).
No firewall is in between switch and NTP server
Switch is able to ping NTP server IP
Using management vlan, not an vrf
Switch9200#sh ntp status
nominal freq is 250.0000 Hz, actual freq is 250.0000 Hz, precision is 2**10
ntp uptime is 6003500 (1/100 of seconds), resolution is 4000
reference time is 00000000.00000000 (05:30:00.000 IST Mon Jan 1 1900)
clock offset is 0.0000 msec, root delay is 0.00 msec
root dispersion is 900.53 msec, peer dispersion is 0.00 msec
loopfilter state is 'NSET' (Never set), drift is 0.000000000 s/s
system poll interval is 8, never updated.
Switch9200#sh ntp associations
address ref clock st when poll reach delay offset disp
~192.168.100.19 .TIME. 16 - 64 0 0.000 0.000 15937.
* sys.peer, # selected, + candidate, - outlyer, x falseticker, ~ configured
switch9200#sh ntp packets
Ntp In packets : 0
Ntp Out packets : 921
Ntp old version packets : 0
Ntp protocol error packets : 0
switch9200#sh run int vlan 11
Building configuration...
Current configuration : 104 bytes
interface Vlan11
description **Mgmt**
ip address 10.168.164.132 255.255.255.0
no ip route-cache
end
switch9200#ping 192.168.100.19 source vlan 11
Sending 5, 100-byte ICMP Echos to 192.168.100.19, timeout is 2 seconds:
Packet sent with a source address of 10.168.164.132
Success rate is 100 percent (5/5), round-trip min/avg/max = 1/1/4 ms
PHH!!!
6 Replies 6
Hello
Initiate an ntp debug and post the results please?
ip  access list extended 100
permit udp host 10.168.164.132 host 192.168.100.19 eq ntp log
permit udp host 192.168.100.19 eq ntp host 10.168.164.132
debug ip packet detail 100
debug ntp packets
Kind Regards
Paul
Leo Laohoo
~192.168.100.19
The "~" means an server is configured but no response from server.
Look at the Linux if ntpd is enabled or not with the command "systemctl is-active ntpd".
M02@rt37
hello @Sharanjeet_Kumar
Do you have this command on your C9200? ntp source Vlan11
Or your Linux (NTP) server do you have already performed a tcpdump and see udp_123 packets ?
On your Linux server, NTP service (chrony ?) is started with no errors ?
Best regards
NTP source is already configured.
while debugging on switch, i didnot see any packets
For tcpdump on ntp server, i am checking
OK @Sharanjeet_Kumar
Thanks for you tcpdump checking.
Best regards
Jens Albrecht
Hello @Sharanjeet_Kumar,
when you verify that the NTP service is actually running on your server, you should also check its config.
Does the NTP server require authentication? If yes, you need to adjust the switch config accordingly.
HTH!
