eBGP local-pref not working
Cars J
Hi All,
I'm trying to balance our 4 Subnets over 2 ISP's using BGP
My situation: we have 4 Public v4 Subnets lets call them (not my real IP's)
NET1: 200.0.1.0/24
NET2: 200.0.2.0/24
NET3: 200.0.3.0/24
NET4: 200.0.4.0/24
I want NET1 and NET2 to use ISP1
I want NET3 and NET4 to use ISP2
With fallback if any of the ISP Links fail.
By default ISP1 has the shortest path to the internet.
So far I was able to use AS-path prepending to influence NET3 and NET4 inbound traffic from Internet to use ISP2
However the outbound traffic is still using ISP1.
I've set Local-Preference in the route-map however testing with trace-route still shows traffic from NET3 and NET4 using ISP1 outbound
Using a Trace-route server in the cloud I see NET3 and NET4 using ISP2 as intended.
Current Config
ip prefix-list NET1 seq 10 permit 200.0.1.0/24
ip prefix-list NET2 seq 10 permit 200.0.2.0/24
ip prefix-list NET3 seq 10 permit 200.0.3.0/24
ip prefix-list NET4 seq 10 permit 200.0.4.0/24
----------Route Map Out--------------
route-map ISP1 permit 10
match ip address prefix-list NET1
set metric 200
route-map ISP1 permit 20
match ip address prefix-list NET2
set metric 200
route-map ISP1 permit 30
match ip address prefix-list NET3
set as-path prepend MY*ASN MY*ASN MY*ASN
set metric 100
route-map ISP1 permit 40
match ip address prefix-list NET4
set metric 100
route-map ISP2 permit 10
set metric 100
route-map ISP2 permit 20
set metric 100
route-map ISP2 permit 30
set metric 200
route-map ISP2 permit 40
set metric 200
----------Route-Map-IN--------------
route-map ISP1-IN permit 10
set local-pref 200
route-map ISP1-IN permit 20
set local-pref 200
route-map ISP1-IN permit 30
set local-pref 50
route-map ISP1-IN permit 40
set local-pref 50
route-map ISP2-IN permit 10
set local-pref 100
route-map ISP2-IN permit 20
set local-pref 100
route-map ISP2-IN permit 30
set local-pref 200
route-map ISP2-IN permit 40
set local-pref 200
router bgp MY*ASN
<snip>
address-family ipv4
neighbor ISP1 route-map ISP1-IN in
neighbor ISP1 route-map ISP1 OUT
neighbor ISP2 route-map ISP2 out
neighbor ISP2 route-map ISP2-IN in
2 Accepted Solutions
If that So you need to use PBR.
Match ACL
Ser next-hop ISP1 or ISP2
MHM
Knonley
Outbound RPL
R1
For prefix first and second --- advertise without any AS-path prepend ---- outbound direction ---- will prefer ISP1
For prefix third and fourth ---- advertise with AS-path prepend ---- outbound direction ---- will prefer ISP2
R2
For prefix first and second --- advertise with AS-path prepend ---- outbound direction ---- will prefer ISP1
For prefix third and fourth ---- advertise without any AS-path prepend ---- outbound direction ---- will prefer ISP2
Inbound RPL
R1
For prefix first and second --- increase LP ---- inbound direction ---- will prefer ISP1
For prefix third and fourth ---- set default LP ---- inbound direction ---- will prefer ISP2
R2
For prefix first and second --- set default LP ---- inbound direction ---- will prefer ISP1
For prefix third and fourth ---- increase LP ---- inbound direction ---- will prefer ISP2
12 Replies 12
Friends you need to use
MED or as-prep
Since these prefix is advertised by your router
LP not work for this case
MHM
Thanks for your advice.
In this case where would i apply the MED? in the route map IN or OUT? to which ISP?
I prefer as-prep
And the direction of route-map is OUT
MHM
@MHM Cisco World wrote:
I prefer as-prep
MHM
This would be okay to influence wan traffic ingress towards OPs rtr, however my understanding the OP needs to traffic engineer outbound traffic based on certain received routes from ISPs as such Weight or LP would be apllicable applied INbound
Kind Regards
Paul
our 4 Subnets <<- I use this as reference' maybe he can confirm if this prefix advertise or receive from router
MHM
Hi, The 4 subnets that I mention we Advertise from our ASN.
Hello
Well then @MHM Cisco World  is correct - AS-path prepend applied Outbound is applicable, so apologies @MHM Cisco World  I misunderstood the OP requiements
Kind Regards
Paul
Friend he more clarify his request check below his reply and my suggestion
MHM
Hi, We Indeed need to traffic engineer Outbound traffic (to the  internet), but not based on received routes. Instead we need to engineer them based on "source" IP subnet.
For Example  I want subnet 200.0.3.0/24 and 200.0.4.0/24 to exit to ISP2. the same path as they are already coming IN.
Thank You.
Match ACL
MHM
Edited -
Now not applicable - misunderstood OP requirements
Kind Regards
Paul
Knonley
Outbound RPL
R1
R2
Inbound RPL
R1
R2
