02-20-2006 03:13 AM - edited 03-03-2019 11:47 AM
I have a 2821 Router with 4 port HSSI module acting as a DTE. Is there a command that shows you what clockrate your receiving from the DCE?
The reason I ask is if I set the DCE to 2Mbps then 8Mbps I see no change on the DTE serial interface in terms on bandwidth settings?
Any help is appreciated
Wayne
02-20-2006 05:05 AM
sh controllers hssi
Clock mux=0x31, ucmd_ctrl=0x8, port_status=0x25
Serial config=0x8, line config=0x1B0202, rx line config=0x80202
maxdgram=1614, bufpool=128Kb, 256 particles
LC=down CA=up TM=down LB=down TA=up LA=down
line state: up
HSSI DTE, received clockrate 16383192
02-20-2006 06:34 AM
Found it, thanks very much. I've now noticed that the clockrate is some 300k less than the DCE is providing.
For example, the DCE is clocking 7680000 and this is confirmed by use of a BERT at X.21. When you plug the Router in it sees the clockrate at something like 7362940 +/-10%.
Is this normal to have such a difference? The clocking is steady and doesn't drift.
Many thanks
Wayne
