Close open DNS resolver?
I have the following config running on an 881 which is connection to an ISP via an external ADSL modem.
In it's current form, it is responding to any DNS request from any external IP address.  I need to close this.  I'm aware I can do this with an ACL but I'm not sure it should be responding in the first place.  Can anyone see a problem with the config?
Current configuration : 2804 bytes
version 15.2
no service pad
service password-encryption
hostname jtg-rtr1
boot-start-marker
boot system flash:c880data-universalk9-mz.152-4.M2.bin
boot-end-marker
no aaa new-model
memory-size iomem 10
clock timezone GMT 0 0
clock summer-time BST recurring
ip dhcp excluded-address 172.16.1.1 172.16.1.99
ip dhcp pool mainPool
import all
network 172.16.1.0 255.255.255.0
default-router 172.16.1.1
dns-server 172.16.1.1
option 66 ascii 172.16.1.1
ip domain name router.local
ip name-server 8.8.8.8
ip name-server 8.8.4.4
ip cef
no ipv6 cef
ip ssh time-out 60
ip ssh authentication-retries 2
csdb tcp synwait-time 30
csdb tcp idle-time 3600
csdb tcp finwait-time 5
csdb tcp reassembly max-memory 1024
csdb tcp reassembly max-queue-length 16
csdb udp idle-time 30
csdb icmp idle-time 10
csdb session max-session 65535
interface FastEthernet0
no ip address
interface FastEthernet1
no ip address
interface FastEthernet2
no ip address
interface FastEthernet3
no ip address
interface FastEthernet4
description ADSL WAN Interface
no ip address
no ip redirects
no ip unreachables
no ip proxy-arp
ip nat outside
ip virtual-reassembly in
duplex auto
speed auto
pppoe enable group global
pppoe-client dial-pool-number 1
no cdp enable
interface Vlan1
ip address 172.16.1.1 255.255.255.0
ip nat inside
ip tcp adjust-mss 1440
no autostate
interface Dialer1
description ADSL WAN Dialler
ip address negotiated
no ip unreachables
ip nat outside
encapsulation ppp
dialer pool 1
ppp authentication chap pap callin
ppp chap hostname [isp username]
ppp chap password [isp password]
ppp ipcp route default
no cdp enable
ip forward-protocol nd
no ip http server
no ip http secure-server
ip dns server
ip nat inside source list 1 interface Dialer1 overload
access-list 1 permit 172.16.1.0 0.0.0.255
dialer-list 1 protocol ip permit
no cdp run
end
John Blakley
Richard,
This line "ip dns server" doesn't need to be enabled to have your hosts get on the internet, but in fact starts the config for the router to answer dns queries. Try "no ip dns server" and see if that resolves your issue.
HTH,
John
*** Please rate all useful posts ***
HTH, John *** Please rate all useful posts ***
Hello
I agree with John regards removing that command
Also as your all importing options from the ISP dhcp you could also change the dhcp pool dns server to that of the ISP
Res
Paul
Kind Regards
Paul
Hi Both,
Thanks for your comments.
Whilst I accept turning off dns-server will work in this particular setup, I am still keen to establish why it's acting in the way it is.
For example, whilst dishing out my ISPs nameserver will work, I would rather my router did this internally.  Surely it must be possible to do this on the internal interface only.
There's not a way that I'm aware of easily to specify "only answer on this interface." You'll probably need to configure reflexive acls or cbac. This will allow the outbound traffic through (your internal hosts to use for forwarding), but should stop queries on the outside.
HTH,
John
