Traffic Shaping issue
Ayman2580
Dears,
     i have Cisco Switch WS-C3750X-48P-S i want to make Traffic shaping on it i tried to make 3 ways useless
1- rate limit on the interface.
2- policy map on the interfase.
3- shaping on the interface level.
4- Command BW on the interface level.
all this didn't work. the IOS is c3750e-universalk9-mz.150-2.SE4.bin and i tried to remove and upgrade it but an error appear
"%Error deleting flash:/c3750e-universalk9-mz.150-2.SE4 (Is a directory)"
any suggestion what to do.
AYman
10 Replies 10
Hello, Ayman.
Real IOS image is inside the directory.
Use "dir flash:/c3750e-universalk9-mz.150-2.SE4" to list directory content (and delete).
Use rmdir to delete directory.
PS: please share your config with MQC that didn't work.
Thanks Mikhailovsky but when i tried to make rmdirer flash:/c3750e-universalk9-mz.150-2.SE4 an error appear as below
Switch#rmdir flash:/c3750e-universalk9-mz.150-2.SE4
Remove directory filename [c3750e-universalk9-mz.150-2.SE4]?
Delete flash:/c3750e-universalk9-mz.150-2.SE4? [confirm]
%Error Removing dir flash:/c3750e-universalk9-mz.150-2.SE4 (Directory not empty)
regarding to the configurations you will find it as you see.
1- using policy map:
class-map match-all TEST
  match access-group 101
policy-map TEST
class TEST
  police 1024000 131072 exceed-action drop
access-list 101 permit ip 10.10.10.0 0.0.0.255 any
under the interface:
service-policy input TEST
2- using rate limit:
same access list
under interface
rate-limit input access-group 101 1048000 131072 147072 conform-action transmit exceed-action drop
3- Traffic Shape under interface:
traffic-shape group 101 1024000 131072 147072
4- Normal Command under inteface
bandwidth 1024.
Ayman,
How are you testing to find out that the configuration above is useless?
Dear John,
     I enabled STG monitoring on the Switch then i initiate a high ping pancket destinated to another interface Vlan50  with IP 83.101.149.57 sourced from my PC 10.10.10.10
interface g1/0/2
ip address 10.10.10.1 255.255.255.0
interface Vlan50
ip address 83.101.149.57 255.255.255.0
then monitor the Traffic on the link although i policed it by 1M it pass 2M.
If you do 'show policy-map' and can you clear the results and then try another test, and past the 'show policy-map' results here for this specific policy?
And just to make sure, you configured a bandwidth of 1024 on his GigabitEthernet1/0/2 interface?
Also, you are only policing inbound and not outbound. So it should be policd to that amount at this port, but outbound traffic will not be policied.
Also can you clear the ACL counters, and paste the results of the 'show access-list' for that specific access list 101 I believe.
thanks for your note regarding to inpount and outbound but they are the same and the limitation didn't apply .
i again tried it and again failed as you ca see from the results it reaches 3 M:
Switch#sh policy-map
  Policy Map TEST
    Class TEST
Switch#sh acce
Switch#sh access-lists
Extended IP access list 101
    10 permit ip 10.10.10.0 0.0.0.255 any
This looks like it is taken in 5 minute intervals. Can you clear all counters/stats on the switch, and then run another test, post the results from 'show policy-map , and 'show int as well?
ok i did as below
Switch#clear access-list counters
Switch#
Switch#clear counters
Clear "show interface" counters on all interfaces [confirm]
Switch#
then make the test and got the same results as pic.
then make the Show you asked for.
Switch#sh policy-map TEST
  Policy Map TEST
    Class TEST
Switch#
interface GigabitEthernet1/0/2
no switchport
end
Switch#
Switch#
  Policy Map TEST
    Class TEST
Switch#sh int g1/0/2
GigabitEthernet1/0/2 is up, line protocol is up (connected)
  Hardware is Gigabit Ethernet, address is f872.ea57.45c5 (bia f872.ea57.45c5)
  Internet address is 10.10.10.1/24
  MTU 1500 bytes, BW 1000000 Kbit/sec, DLY 10 usec,
  Keepalive set (10 sec)
  Full-duplex, 1000Mb/s, media type is 10/100/1000BaseTX
  input flow-control is off, output flow-control is unsupported
  Last input 00:00:00, output 00:00:00, output hang never
  Last clearing of "show interface" counters 00:03:02
  Input queue: 11/75/0/0 (size/max/drops/flushes); Total output drops: 0
  Queueing strategy: fifo
  Output queue: 0/40 (size/max)
  5 minute input rate 1804000 bits/sec, 181 packets/sec
  5 minute output rate 1740000 bits/sec, 159 packets/sec
     30442 packets input, 39463480 bytes, 0 no buffer
     Received 328 broadcasts (0 IP multicasts)
     0 watchdog, 21 multicast, 0 pause input
     26878 packets output, 38555350 bytes, 0 underruns
     0 unknown protocol drops
     0 lost carrier, 0 no carrier, 0 pause output
Switch#sh run int g1/0/2
If you ook at the below values
Input - 1804000/8 = 225500 bytes = 0.215 Mbps
Output - 1740000 = 217500 bytes = 0.207 Mbps.
This is in a 5 minute sliding window.
Hello
For vlan based mls qos try this:
Class-map TEST
Match input interface gig1/0/2
Match access-group 101
interface g1/0/2
Mls qos vlan-based
interface Vlan50
Load interval 30
Tes
Paul
Kind Regards
Paul
