Collision on Fast Ethernet
nasheer.ahmad
Dear Experts,
I am getting the below log from one of the router.Can you pls suggest the steps to find the exact reason from where the collisions are generating.
1. Cabling is OK
2. We are not using HUBS on that location.
3. systems are also branded one (HP)
%PQUICC_FE-5-LATECOLL: PQUICC/FE(0/0), Late collision
regds
Pravin Phadte
Level 5
Level 5
This would be be the hubs causing the problem and the cause for the error.
It can also be a possiblity of the LAN card faulty on the machines.
Try to check the duplex on the router.
