Command show ip route in asr 1k
wfqk
Level 5
Level 5
hi When using command "show ip route", there are a lot output. I do not want to check one by one. I want to know if there is command which can directly show how many routes the router has without checking the number, Do we have this command? Thank you
Hi @wfqk
Try "show up route summary" otherwise you can use a script or some specific tool for that.
-If I helped you somehow, please, rate it as useful.-
Hi @wfqk
