12-11-2017 06:31 PM - edited 03-05-2019 09:37 AM
Currently I have 2 MPLS of the same provider, MPLS A 40M and MPLS B 20M. I have a few VLAN for different purpose, VLAN 10, 20, 30, 40, 50 for infrastructure(and normal users) and VLAN 60 for VIP users.
My intention here is to use the 40M for infrastructure VLANS and 20M for VLAN 60 which is VIP access. So VLAN 10 to 50 will use MPLS A and VIP users will all be on MPLS B. So when MPLS A fail, all VLANs will pass via MPLS B and vice versa for MPLS B failover to MPLS A.
Currently, i have all VLANs advertised on both MPLS.
1. Is there any way i could use IP SLA to help me in failover at core switch level?
2. If i could use IP SLA to failover at MPLS end which instead of advertising all VLANS in both MPLS, i will advertise required VLAN at each MPLS and IP SLA to advertise the rest of the segments when i failover.
Please help me out here.
Solved! Go to Solution.
12-12-2017 06:30 PM
12-11-2017 08:15 PM
12-12-2017 12:55 AM
I don't have visibility on ISP router, as far as i know, individual /24 is advertised out to the MPLS probably via static redistribution. There is no dynamic routing in place between core switch and MPLS router too.
12-12-2017 01:56 AM - edited 12-12-2017 01:57 AM
Hello
If you dont have no control on whats being advertise into your ISP PE edge rtrs then its seem you may need to liaise with your ISP as to what you want then to advertise on your behalf .
res
Paul
12-12-2017 03:27 PM
12-12-2017 05:46 PM
I do understand but seems like SP is not sending the right person to help us on this so i have to seek help here. I am also hoping to understand more on IP SLA, like can i actually trigger a set of commands for the interface if the IP SLA lose track of the reachability.
12-12-2017 06:30 PM
