command 'show ip route summary'
ubaidullahhanif
I dont understand the Networks and Replicates column under command 'show ip route summary'..plz someone elaborate it...and also the values under Networks column..thanks!
OSRBAG-GW01#show ip route summary
IP routing table name is default (0x0)
IP routing table maximum-paths is 32
Route Source    Networks    Subnets     Replicates  Overhead    Memory (bytes)
connected               0           35                0            2108           6020
static                      0           0                  0              0                0
ospf 10                   7        2536                0           153296        447568
  Intra-area: 228 Inter-area: 150 External-1: 0 External-2: 2165
  NSSA External-1: 0 NSSA External-2: 0
internal                 21                                                              107348
Total                     28          2571              0           155404        560936
0 Replies 0
