Command to check supervisor crc error threshold is needed!
michael.ledzbor
Hi Colleagues,
We have seen the following message on a  CISCO 7609-S (12.2(33)SRD3):
%FABRIC_INTF_ASIC-4-FABRICCRCERRS: Fabric ASIC 0: 239 Fabric CRC error events in 100ms period
Explanation (Output Interpreter): The Switch Fabric interface Fabric interface encountered more crc
error    events than the Supervisor crc error threshold allows.
We would like to check the current crc error counter and crc error threshold on the supervisor.
Does anybody know which commands have to be issued to get this information?
Many thanks in advance!
BR
Mike
John Blakley
Try here:
http://www.cisco.com/en/US/products/hw/switches/ps700/products_tech_note09186a00801c6652.shtml#truncated
If you're using truncated, it looks like the default threshold is 2.
You may also want to look at Switch Fabric Module Redundancy in the same document.
John
HTH, John *** Please rate all useful posts ***
Ivan Krimmel
Level 7
Level 7
Hi Mike,
please take off the following outputs several times with a slight interval between them:
show fabric channel-counters
show fabric errors
show fabric drops
remote command switch sh fabric errors
it might be a one time occurence(most likely).
Cheers,
Ivan.
