Command to show history of issues on a router?
fentressema3
I've tried looking through the forum and in Google for the simple command to Show history for issues that occurred on a cisco router. Is there one single command that will show all history of issues? I know there are specific commands for CRC errors, but is there just a general command?
Thanks!
Giuseppe Larosa
Hello @fentressema3 ,
for events occurred since last reboot
you can use
show log
For very critical events that cause the router to crach the router attempts to write a crashinfo file on the flash
So for serious issues look for crashinfo files using
dir flash:
or dir   /all
the crashinfo files contain binary info that are core dumps from router memory you would need to download the Cisco Analyzer or to submit them to Cisco TAC ( you need a valid contract)
Hope to help
Giuseppe
