Commands not shows via ssh - ASR9K
mburgos07
I have a ASR9K with version  mbiasr9k-rp.vm. When he run a command show log, dir or other command via ssh not shows the logs. If he run via console, the commands appear.
RP/0/RSP0/CPU0:BRSPOM1COMM-ASR9K-1#sh logging
Mon Sep 2 11:48:28.403 GMT
RP/0/RSP0/CPU0:BRSPOM1COMM-ASR9K-1#dir
Mon Sep 2 11:53:11.518 GMT
Anyone know why it´s occurring?
Thanks!
Marcelo
amabdelh
Marcelo
I don't expect there is an issue with the router, can you check this using a different client?
Hi Amjad,
I´m sorry for delay. I opened a TAC case and this problem is related a bug CSCte01589.
Bugs: CSCte01589    Unable to execute commands through telnet/ssh session
Resolution Steps: I restarted the devc-vty process on from the console of the router to recover from this issue.
Resolution Summary:
This is a known bug that is not fixed until 3.9.2 and 4.0.0 and higher.
Here is the bug for this problem.  It's fixed in 3.9.2 and 4.0.0 and higher.
Symptom:
telnet/ssh to the router prints incomplete output and then hangs. It does not respond to "ENTER". It may respond to CTRL-C but this does not restore a complete correct behavior.
Conditions:
This happens after multiple VTY sessions being opened and closed at the same time, or after a session has been terminated while still receiving output.
Workaround:
  Using "terminal length 0" is a partial workaround.
Recovery:
  Create a new telnet/ssh session. FIRST command to execute from this session is  "proc restart devc-vty".
  OR
  Connect to the router through a Console  port
Thanks for your help.
Marcelo
