09-27-2013 06:34 AM - edited 03-04-2019 09:10 PM
Hello we had cisco 1720 router with a WIC-1T for a point to point T1 between two of our sites. The 1720 cratered so I scrounged and found a 2600 that showed compatible with the WIC-1T so we moved it to the 2600. I cannot get it to go up/up. Attached is my config and the interface status. Is there possibly something I might be missing on the config? Its very basic and I just essentially mirrored the old config. I am at a loss as to why the serial is not coming up, I had telco check the circuit and they say it is good end to end.
09-27-2013 06:47 AM
sh diag
sh ver
09-27-2013 06:54 AM
09-27-2013 07:08 AM
Ok,
1.Do you use the same encapsulation and same keepalive values in both sites?
If it possible ... sh in int serial x/x and sh run int se0/0 from other site.
2. Show contr serial x/x from 2600
09-27-2013 07:19 AM
09-27-2013 07:32 AM
debug serial interface from both sides -)
09-27-2013 08:01 AM
Turned on both sides, watching consoles not seeing any output. Still staring....
09-27-2013 08:23 AM
Ok realized I needed to turn on packet debugging as well. All I get is this over and over on the bad side where we replaced the router, still nothing on other end.
22:07:36: Serial0/0: HDLC myseq 689, mineseen 0, yourseen 0, line down
22:07:46: Serial0/0: HDLC myseq 690, mineseen 0, yourseen 0, line down
22:07:56: Serial0/0: HDLC myseq 691, mineseen 0, yourseen 0, line down
22:08:05: Serial0/0: attempting to restart
22:08:05: PowerQUICC(0/0): DCD is up.
22:08:06: Serial0/0: HDLC myseq 692, mineseen 0, yourseen 0, line down
22:08:16: Serial0/0: HDLC myseq 693, mineseen 0, yourseen 0, line down
22:08:26: Serial0/0: HDLC myseq 694, mineseen 0, yourseen 0, line down
22:08:35: Serial0/0: attempting to restart
22:08:35: PowerQUICC(0/0): DCD is up.
22:08:36: Serial0/0: HDLC myseq 695, mineseen 0, yourseen 0, line down
22:08:46: Serial0/0: HDLC myseq 696, mineseen 0, yourseen 0, line down
22:08:56: Serial0/0: HDLC myseq 697, mineseen 0, yourseen 0, line down
22:09:05: Serial0/0: attempting to restart
22:09:05: PowerQUICC(0/0): DCD is up.
09-27-2013 08:55 AM
Ok realized I needed to adjust logging on the good side to get output. looks the same:
09-27-2013 10:54:28 Local7.Debug 192.168.85.14 46: 23:17:33: Serial0: HDLC myseq 75, mineseen 0, yourseen 0, line down
09-27-2013 10:54:18 Local7.Debug 192.168.85.14 45: 23:17:23: Serial0: HDLC myseq 74, mineseen 0, yourseen 0, line down
09-27-2013 10:54:17 Local7.Debug 192.168.85.14 44: 23:17:21: QUICC_SERIAL(0): Reset from 0x80270A6
09-27-2013 10:54:17 Local7.Debug 192.168.85.14 43: 23:17:21: Serial0: attempting to restart
09-27-2013 10:54:08 Local7.Debug 192.168.85.14 42: 23:17:13: Serial0: HDLC myseq 73, mineseen 0, yourseen 0, line down
09-27-2013 10:53:58 Local7.Debug 192.168.85.14 41: 23:17:03: Serial0: HDLC myseq 72, mineseen 0, yourseen 0, line down
09-27-2013 10:53:48 Local7.Debug 192.168.85.14 40: 23:16:53: Serial0: HDLC myseq 71, mineseen 0, yourseen 0, line down
09-27-2013 10:53:47 Local7.Debug 192.168.85.14 39: 23:16:51: QUICC_SERIAL(0): Reset from 0x80270A6
09-27-2013 10:53:47 Local7.Debug 192.168.85.14 38: 23:16:51: Serial0: attempting to restart
09-27-2013 10:53:38 Local7.Debug 192.168.85.14 37: 23:16:43: Serial0: HDLC myseq 70, mineseen 0, yourseen 0, line down
09-27-2013 10:53:29 Local7.Debug 192.168.85.14 36: 23:16:33: Serial0: HDLC myseq 69, mineseen 0, yourseen 0, line down
09-27-2013 10:53:18 Local7.Debug 192.168.85.14 35: 23:16:22: Serial0: HDLC myseq 68, mineseen 0, yourseen 0, line down
09-27-2013 10:53:17 Local7.Debug 192.168.85.14 34: 23:16:21: QUICC_SERIAL(0): Reset from 0x80270A6
09-27-2013 10:53:17 Local7.Debug 192.168.85.14 33: 23:16:21: Serial0: attempting to restart
09-27-2013 10:53:08 Local7.Debug 192.168.85.14 32: 23:16:12: Serial0: HDLC myseq 67, mineseen 0, yourseen 0, line down
09-27-2013 10:52:58 Local7.Debug 192.168.85.14 31: 23:16:02: Serial0: HDLC myseq 66, mineseen 0, yourseen 0, line down
