%COMMON_FIB-6-FIB_RECURSION: has too many (8) levels of recursion during process switch
Jared Oliver
I often get this message in my logs;
Does anyone have any idea what this means? This same router has, on average, one disconnect from our GRE tunnel each day and I can't connect to it externally until the cable modem is rebooted. The log above is the only thing I've got to go on really. Everything else looks normal.
Thanks!
Don2001L
Hello Jared,
That message means you have a routing issue.
I had the same thing occur on a couple of routers that * Swapped* places in my Lab as I had not updated the configuration on each one "Correctly"
Check what "show ip route" returns and adjust it accordingly.
Bad routing was the problem in my situation - it might not be the same for you.
Have Fun,
Don
Humanoid
there is something between routing make FIB recursion issue,
can you share the config of router ??
The problem configuration is gone now -
2 Routers
Router1
0/0 10.0.0.0
0/1 20.0.0.0
Router 2
0/0 20.0.0.0
0/1 30.0.0.0
IP route statements were left in the "Other Router" for what used to be 10 and what used to be 30 for " How to get to 10 / 30 "
Some BGP and OSPF config tests were also present - so its comparing apple and Lemons.
just trying to give Jared someplace to start looking for a 7 Year Old post
Don
Humanoid
sorry I see the date now, I thought it new post.
anyway
Yes the routing must config right for GRE tunnel otherwise the routing for tunnel is through tunnel itself
