Common shaper on sub-interfaces
Vlad8
Is it possible to shape traffic on two sub-interfaces using a common(aggregate) shaper policy?
There is a trunk interface on Cisco ISR4331 with multiple sub-interfaces that have assigned output shaper policies.
interface GigabitEthernet0/0/1
! no service policies
interface GigabitEthernet0/0/1.100
 service-policy output SHAPER-OUT-10Mbps
interface GigabitEthernet0/0/1.101
interface GigabitEthernet0/0/1.102
 service-policy output SHAPER-OUT-15Mbps
policy-map SHAPER-OUT-10Mbps
 class class-default
  shape average 10000000
   service-policy WAN-OUT
policy-map WAN-OUT
 class WAN-Class1
  priority percent 60
 class WAN-Class2
  bandwidth remaining percent 10
  random-detect dscp-based
 class WAN-Class3
  bandwidth remaining percent 4
  random-detect
 class WAN-Class4
  random-detect dscp 2 8 40 10
  random-detect dscp 4 8 40 10
  random-detect dscp 6 4 40 10
 class class-default
Is it possible to have a common shaper on interfaces Gi0/0/0.100 and Gi0/0/0.101 that will limit combined bandwidth from these two interfaces instead of shaping bandwidth on each one of them individually?
The existing configuration permits reaching a maximum of 10 Mbps on both interfaces individually; however, if one is underutilized, the second one can't use the available bandwidth of up to 20 Mbps in total.
The ultimate goal is to allow Gi0/0/0.100 and Gi0/0/0.101 to utilize up to a combined bandwidth of 20 Mbps, respecting the classes.
To provide more context, just imagine that behind there is a physical channel that carries only these two VLANs, which is limited to 20 Mbps and does not support QoS. The goal is to maximize the usage of this pipe while respecting QoS, and not affecting traffic on other sub-interfaces such as Gi0/0/0.102.
12 Replies 12
Joseph W. Doherty
Maybe.  I'm not certain.
You might try a policy on the main interface which has a class that matches the traffic of the two interfaces and shape for the aggregate.
Here's what I have in mind (w/o including shaper for 3rd subinterface) - but again, unsure it will work correctly.
ip access-list extended Example
 permit ip {subinterface 1's traffic attributes}
 permit ip {subinterface 2's traffic attributes}
class-map match-? Example
 match access-group name Example
! and (match-all) or (match-any)
 match {some other subinterface 1's and 2's traffic attributes}
policy-map Example
 class Example
  shape average 8000
interface GigabitEthernet0/0/0
 no ip address
 service-policy output Example
interface GigabitEthernet0/0/0.1
 encapsulation dot1Q 1
interface GigabitEthernet0/0/0.2
 encapsulation dot1Q 2
 ip address 192.168.2.1 255.255.255.0
interface GigabitEthernet0/0/0.3
 encapsulation dot1Q 3
 ip address 192.168.3.1 255.255.255.0
Oops, actually the ACL would need to match the traffic flowing across the subinterfaces, so just matching the subinterface's subnet, isn't correct.
H-QoS via policy aggregation?
Disclaimers: I am long in CSCO. Bad answers are my own fault as they are not AI generated.
Maybe!
If OP only wants just one specific set of combined subinterfaces, and the other subinterfaces independent, as they currently are (?), and the existing policies only shape the default class, it may be a very suitable approach.
If the need is more complex, likely this feature, even possibly the later XE 2.6 variant, might not be up to challenge.
BTW, what I suggested, is dependent on the main interface "seeing" all the subinterface traffic in a policy applied to it.  This may not be the case, or it may work on some platform/IOS combos, and not others.  (When you start really pushing complexity in MQC, I've often seen one platform/IOS accept a config that another platform/IOS does not.)
I don't have any hardware to test with.  Do have a copy of CML, which might accurately provide a faithful result.
I'm also wondering whether "match vlan #" would work on the main interface.
from: https://www.cisco.com/c/en/us/td/docs/ios-xml/ios/qos_mqc/configuration/xe-16-12/qos-mqc-xe-16-12-book/qos-intro.html
policy-map child
  class voice
    priority
    police cir percent 10
  class video
    bandwidth remaining percent 30
policy-map parent-vlan100
  class class-default
    shape average 100m
    service-policy child
policy-map parent-vlan200
  class class-default
    shape average 50m
int gigabitethernet1/0/0.100
  service-policy out parent-vlan100
int gigabitethernet1/0/0.200
  service-policy out parent-vlan200
This example shows that although the definition may be shared the instances of the policy on different interfaces are truly unique.
You can also create hierarchical policies with policy-maps used in user-defined classes.
The following example illustrates a 3-level hierarchical policy, the max currently supported on the ASR 1000 Series Router. For a packet to match a class at the application level it must now match 3 requirements: the voice or video classifier at the child, the vlan classifier in the vlan-sharing policy-map, and the class-default (anything) in the physical level policy-map:
class-map vlan100
  match vlan 100
class-map vlan200
  match vlan 200
policy-map child
  class voice
    priority
  class video
policy-map vlan-sharing
  class vlan100
    shape average 100m
  class vlan200
    shape average 50m
policy-map physical-policy
  class class-default
    shape average 500m
    service-policy vlan-sharing
interface gigabitethernet1/0/0
  service-policy out physical-policy
In the above, the first portion, is probably somewhat similar to what OP is doing now.
The second portion, is what I had in mind, more or less.  (I've often done similar QoS with multiple tunnels crossing a physical interface, just not with router subinterfaces.)
Assuming the second portion works, it might require being used exclusively, i.e. you might not be able to mix the two techniques on the same interface.  (Not a big deal if you only have a few, like the OP's 3, but if you have hundreds, then you might have a major conversion effort.)
Again, I've often seen complex QoS configs impacted by their level of complexity.  So, @Vlad8 can you provide an example of what your subinterface policies are (actually) now?
PS:
BTW, Jim, I wasn't aware of the feature you referenced.  Reading it though, it seems inferior to the above because I usually find I need a multi-level hierarchal policy when shaping, not aggregation of multiple streams.  Again, though, perhaps it would be suitable for OP.
The usual case I've had to deal with, having a hub with a 10x the bandwidth of spoke sites, but more than 10 spoke sites.  So, from the hub, need to deal with its overall bandwidth limit, (to) spoke bandwidth limits, and prioritization of traffic when either the hub or  (to) spoke bandwidth limits are exceeded.
@Joseph W. DohertyI've updated the post and included the policy. To provide more context, just imagine that there is a physical channel that carries only these two VLANs, which is limited to 20 Mbps and does not support QoS. The goal is to maximize the usage of this pipe while respecting QoS.
Possibly:
 service-policy output VLANS-100-n-101-SHAPER-OUT-20Mbps
! service-policy output SHAPER-OUT-10Mbps
 class class-default
policy-map VLANS-100-n-101-SHAPER-OUT-20Mbps
 class VLANS-100-n-101
  shape average 20000000
class-map match-any VLANS-100-n-101
 match vlan 100
 match vlan 101
It doesn't let to attach the service policy to the main interface
(config)#interface GigabitEthernet0/0/0
(config-if)#service-policy output VLANS-100-101-AGGREGATE-SHAPER-20Mbps
Service_policy with queueing features on this interface is not allowed
if service-group/evc queuing policy is already installed Remove service-group/evc policy first and then install policy on this interface and later on service-group/evc
%QOS-6-POLICY_INST_FAILED: Service policy installation failed on GigabitEthernet0/0/0. service-policy not applicable for interface features. policy:VLANS-100-101-AGGREGATE-SHAPER-20Mbps, dir:OUT, ptype:, ctype:DEFAULT
Error appears to be about sequence of application (which I've sometimes seen).  Also, did you remove policies from those two subinterfaces first?
For the former, it may require you first remove all subinterface policies, then apply policy on main interface, then reapply subinterface policies.
It may also turn out it won't support policies on both main and subinterfaces, concurrently.  If so, and if main policy works correctly matching VLANs, you could do all your QoS in just a main interface policy, although limited by max number of classes per policy.
Yup, you're right - it doesn't support policies on both main and sub-interfaces, concurrently.
So, the final config, which I'm going to test, looks like this:
class-map match-any AGGREGATE-QoS_VLANS_100_101
 match vlan  100
 match vlan  101
class-map match-any AGGREGATE-QoS_VLAN_102
 match vlan  102
policy-map Gi0-0-0_AGGREGATE-SHAPER
 class AGGREGATE-QoS_VLANS_100_101
 class AGGREGATE-QoS_VLAN-102
  shape average 15000000
interface GigabitEthernet0/0/0.100
 no service-policy output SHAPER-OUT-10M
interface GigabitEthernet0/0/0.101
interface GigabitEthernet0/0/0.102
 no service-policy output SHAPER-OUT-15M
 service-policy output Gi0-0-0_AGGREGATE-SHAPER
Looks okay.  Just now a question whether it will accept it and work as desired.
Ahhh yes, it did accept the config on a lab router. By 'test,' I meant a traffic load test to verify that it works as desired.
