Comms between 2 VPN's on an ASA 7.x
MrFlibbleuk
Hi Everyone,
We have a setup on an ASA with two ipsec tunnels. One to Site A (10.0.1.x) and one to Site B (10.0.2.x), incidentally Head office where the ASA is located is 10.0.0.x, we now need to set it up so that Site A can communicate with Site B.
I have carried out some investigation and I know that I need to use the same-security-traffic permit intra-interface command to allow traffic to come in and out of the same interface but I still cant get things to work.
I configured both sites of the tunnel for Site A and Site B to allow traffic from 10.0.1.x to 10.0.x.x, 10.0.2.x to 10.0.x.x.
Actually here is the config, does anyone have any ideas?? Would really appreciate it as I am running around in circles....
access-list acl-outside extended permit ip 10.0.1.0 255.255.255.0 10.0.2.0 255.255.255.0
access-list acl-outside extended permit ip 10.0.2.0 255.255.255.0 10.0.1.0 255.255.255.0
access-list acl-outside remark --- Permit Inbound access from Site A ---
access-list acl-outside extended permit ip 10.0.1.0 255.255.255.0 10.0.0.0 255.255.0.0
access-list acl-outside remark --- Permit Inbound access from Site B ---
access-list acl-outside extended permit ip 10.0.2.0 255.255.255.0 10.0.0.0 255.255.0.0
access-list acl-inside remark --- Permit Outbound Access to Site A ---
access-list acl-inside extended permit ip 10.0.0.0 255.255.0.0 10.0.1.0 255.255.255.0
access-list acl-inside remark --- Permit Outbound Access to Site B ---
access-list acl-inside extended permit ip 10.0.0.0 255.255.0.0 10.0.2.0 255.255.255.0
access-list vpn-siteA remark --- Encrypt traffic to Site A ---
access-list vpn-siteA extended permit ip 10.0.0.0 255.255.0.0 10.0.1.0 255.255.255.0
access-list vpn-siteB remark --- Encrypt traffic to Site B ---
access-list vpn-siteB extended permit ip 10.0.0.0 255.255.0.0 10.0.2.0 255.255.255.0
access-list inside_nat0_outbound remark --- NONAT for Site A ---
access-list inside_nat0_outbound extended permit ip 10.0.0.0 255.255.0.0 10.0.1.0 255.255.255.0
access-list inside_nat0_outbound remark --- NONAT for Site B ---
access-list inside_nat0_outbound extended permit ip 10.0.0.0 255.255.0.0 10.0.2.0 255.255.255.0
global (outside) 1 interface
nat (inside) 0 access-list inside_nat0_outbound
nat (inside) 1 10.0.0.0 255.255.255.0
access-group acl-outside in interface outside
access-group acl-inside in interface inside
route outside 0.0.0.0 0.0.0.0 x.x.x.x
crypto ipsec transform-set ESP-3DES-SHA esp-3des esp-sha-hmac
crypto ipsec security-association lifetime seconds 86400
crypto map outside_map 20 match address vpn-siteA
crypto map outside_map 20 set peer x.x.x.x
crypto map outside_map 20 set transform-set ESP-3DES-SHA
crypto map outside_map 20 set security-association lifetime seconds 28800
crypto map outside_map 25 match address vpn-siteB
crypto map outside_map 25 set peer x.x.x.x
crypto map outside_map 25 set transform-set ESP-3DES-SHA
crypto map outside_map 25 set security-association lifetime seconds 28800
crypto map outside_map interface outside
crypto isakmp enable outside
crypto isakmp policy 10
authentication pre-share
encryption 3des
hash sha
group 2
lifetime 86400
acomiskey
Level 10
Level 10
It looks like you may need to add the interesting traffic for the communication between the remote lans.
access-list vpn-siteA extended permit ip 10.0.2.0 255.255.0.0 10.0.1.0 255.255.255.0
access-list vpn-siteB extended permit ip 10.0.1.0 255.255.0.0 10.0.2.0 255.255.255.0
Please rate helpful posts.
You will also need to add the interesting traffic to the acl's at the remote sites as well.
SiteA needs...
access-list extended permit ip 10.0.1.0 255.255.0.0 10.0.2.0 255.255.255.0
SiteB needs...
access-list extended permit ip 10.0.2.0 255.255.0.0 10.0.1.0 255.255.255.0
