Compact Flash for Router 2911
The compact flash with code 16-3260-01 works on Router 2911?
See the picture att
Tks.
Vinit Jain
Hello Alexandre
I think it should be supported, since its a 256Mb CF memory card.
The code that you mentioned, i dont see any information on Cisco.com website but do have many references on ebay or other sites.
Hope this helps.
Vinit
--Vinit
