Computer cannot connect to the internet, however router can
Jasonsp
Hello Everyone
I am building a home lab to practice on real equipment for Exams. I have gone through some sites trying to find a solution to my problem, but I am falling short.
Any help would be greatly appreciated.
Router show run
Building configuration...
Current configuration : 1549 bytes
! Last configuration change at 01:05:40 UTC Wed Aug 19 2020
version 15.4
hostname Router
boot-start-marker
boot-end-marker
no aaa new-model
ip dhcp excluded-address 10.0.1.1 10.0.1.10
ip dhcp pool PC NETWORK
network 10.0.1.0 255.255.255.0
default-router 10.0.1.1
dns-server 8.8.8.8 8.8.8.4
ip cef
no ipv6 cef
cts logging verbose
license udi pid CISCO1921/K9 sn FGL220790TL
redundancy
interface Embedded-Service-Engine0/0
no ip address
shutdown
interface GigabitEthernet0/0
description INTERNET
ip address dhcp
ip nat outside
ip virtual-reassembly in
duplex auto
speed auto
interface GigabitEthernet0/1
no ip address
duplex auto
speed auto
interface GigabitEthernet0/1.10
description PC NETWORK
encapsulation dot1Q 10 native
ip address 10.0.1.1 255.255.255.0
ip nat inside
ip forward-protocol nd
no ip http server
no ip http secure-server
ip nat inside source list 100 interface GigabitEthernet0/1.10 overload
ip route 0.0.0.0 0.0.0.0 GigabitEthernet0/0 dhcp
access-list 100 permit ip 10.0.1.0 0.0.0.255 any
control-plane
line con 0
line aux 0
line 2
no activation-character
no exec
transport preferred none
transport output pad telnet rlogin lapb-ta mop udptn v120 ssh
stopbits 1
line vty 0 4
login
transport input none
scheduler allocate 20000 1000
end
Router show ip interface brief
Embedded-Service-Engine0/0 unassigned YES NVRAM administratively down down
GigabitEthernet0/0 10.0.0.220 YES DHCP up up
GigabitEthernet0/1 unassigned YES NVRAM up up
GigabitEthernet0/1.10 10.0.1.1 YES NVRAM up up
NVI0 unassigned YES unset administratively down down
Switch show run
Current configuration : 1348 bytes
version 12.2
no service pad
hostname Switch
boot-start-marker
boot-end-marker
no aaa new-model
system mtu routing 1500
spanning-tree mode pvst
vlan internal allocation policy ascending
interface FastEthernet0/1
interface FastEthernet0/2
interface FastEthernet0/3
interface FastEthernet0/4
interface FastEthernet0/5
interface FastEthernet0/6
interface FastEthernet0/7
interface FastEthernet0/8
interface FastEthernet0/9
interface FastEthernet0/10
interface FastEthernet0/11
interface FastEthernet0/12
interface FastEthernet0/13
interface FastEthernet0/14
interface FastEthernet0/15
interface FastEthernet0/16
interface FastEthernet0/17
interface FastEthernet0/18
interface FastEthernet0/19
interface FastEthernet0/20
interface FastEthernet0/21
interface FastEthernet0/22
interface FastEthernet0/23
interface FastEthernet0/24
switchport mode trunk
interface GigabitEthernet0/2
interface Vlan1
no ip address
interface Vlan10
ip address 10.0.1.2 255.255.255.0
no ip http server
line con 0
line vty 0 4
login
line vty 5 15
login
end
2 Accepted Solutions
Hello @Jasonsp ,
on the the router you have configured
the nat statement must refer to the external interface the one with the ip nat outside statement
so the following changes:
Router:
config t
no ip nat inside source list 100 interface GigabitEthernet0/1.10 overload
ip nat inside source list 100 interface GigabitEthernet0/0 overload
Hope to help
Giuseppe
Hi Jason,
My apologies for misleading you - you are correct, if you have VLAN 10 set as the native VLAN on your router's subinterface, then there is no need to place any access switchports in VLAN 10 on the switch.
With that being said, I would recommend that you either remove the native VLAN setting on the router's subinterface, or explicitly add it as the native VLAN on your switch's trunk and explicitly place access switchports in VLAN 10. With your current configuration, packets in VLAN 1 on the switch turn into packets in VLAN 10 on the router. While there's nothing inherently wrong with that, it can be a bit more difficult to troubleshoot.
I believe @Giuseppe Larosa's answer is correct - I missed that your NAT/PAT statement is pointing towards the inside interface, not the outside interface. As Giuseppe explained, you will need to modify this configuration such that the outside NAT interface is overloaded instead of the inside interface.
Thank you!
-Christopher
6 Replies 6
Christopher Hart
Hi Jason!
From a quick glance at your switch's configuration, it doesn't look like there are any access switchports configured for VLAN 10.
Can you confirm what specific interface on your switch you have a client (such as a PC, server, etc. that you would like to connect to the Internet) connected to?
Can you also verify that this interface is configured to be an access switchport (via the switchport mode access command) in VLAN 10 (via the switchport access vlan 10 command)?
Thank you!
-Christopher
Hello Christopher,
If you configured the router gig0/1.10 as encapsulation dot1q 10 native, do you still need to do switchport mode access?
The computer is connect to gig 0/2 on the switch.
Thank you
Hello @Jasonsp ,
Router:
config t
Hope to help
Giuseppe
Thank you
I have been racking my brain on why this hasn't been working and it turns out I put in the wrong port.
I cannot thank you enough.
Hi Jason,
Thank you!
-Christopher
I did some looking into whether to change it back and do switchport mode access instead of having it as a native. Seems its better to just do switchport mode access, than naming something other than Vlan1 as native/default. For example CDP will always go over Vlan1 whether its the default or not, if its not the default then CDP still uses Vlan1, it just turns into tagged traffic.
I will be switching back to having Vlan1 as native, and just doing switchport mode access on devices on Vlan 10.
Thank You for your help Christopher.
I very much appreciate it.
