Issues with DHCP server on Cisco 1841
radiomean
Hi, this is a simple issue but I have been looking at documentation and I can't get anywhere so I will ask the experts...
I am setting up a DHCP server on an 1841 router with a HWIC-AP-AG card. It's running IOS 15.1(3)T2 adventerprise with 256 Mb of ram.
((I know it's all old tech but I have my reasons!))
I am simply using the HWIC-AP card as an access point. I have manually assigned an IP address of 192.168.2.1 to the g wireless and 192.168.5.1 to the a wireless.
I've configured the following DHCP pool:
no ip dhcp conflict logging
ip dhcp excluded-address 192.168.2.1 192.168.2.32
ip dhcp pool two
network 192.168.2.0 255.255.255.0
default-router 192.168.2.1
dns-server 8.8.8.8 8.8.4.4
domain-name ****.com
lease 0 2
I can associate a laptop fine and access the router using static IP but when I try to use DHCP an address is briefly assigned, then declined and a self-determined IP appears on the laptop. And the next IP address is then assigned and so on...
The output of the DHCP server is below:
*Aug 17 22:03:10.226: %DOT11-6-ASSOC: Interface Dot11Radio0/1/0, Station c49d.ed07.06aa Associated SSID[ciscotest2] AUTH_TYPE[OPEN] KEY_MGMT[NONE]
*Aug 17 22:03:14.826: DHCPD: client's VPN is .
*Aug 17 22:03:14.826: DHCPD: Sending notification of DISCOVER:
*Aug 17 22:03:14.826: DHCPD: htype 1 chaddr c49d.ed07.06aa
*Aug 17 22:03:14.826: DHCPD: remote id 020a0000c0a8020101000000
*Aug 17 22:03:14.826: DHCPD: circuit id 00000000
*Aug 17 22:03:14.826: DHCPD: DHCPDISCOVER received from client 01c4.9ded.0706.aa on interface Dot11Radio0/1/0.
*Aug 17 22:03:14.826: DHCPD: Seeing if there is an internally specified pool class:
*Aug 17 22:03:14.830: DHCPD: Found previous server binding
*Aug 17 22:03:14.830: DHCPD: Sending DHCPOFFER to client 01c4.9ded.0706.aa (192.168.2.41).
*Aug 17 22:03:14.830: DHCPD: no option 125
*Aug 17 22:03:14.830: DHCPD: broadcasting BOOTREPLY to client c49d.ed07.06aa.
*Aug 17 22:03:14.858: DHCPD: client's VPN is .
*Aug 17 22:03:14.858: DHCPD: DHCPREQUEST received from client 01c4.9ded.0706.aa.
*Aug 17 22:03:14.858: DHCPD: Sending notification of ASSIGNMENT:
*Aug 17 22:03:14.858: DHCPD: address 192.168.2.41 mask 255.255.255.0
*Aug 17 22:03:14.858: DHCPD: htype 1 chaddr c49d.ed07.06aa
*Aug 17 22:03:14.858: DHCPD: lease time remaining (secs) = 7200
*Aug 17 22:03:14.858: DHCPD: Appending default domain from pool
*Aug 17 22:03:14.858: DHCPD: Using hostname 'DESKTOP-SURFACE.****.com.' for dynamic update (from FQDN option)
*Aug 17 22:03:14.858: DHCPD: Sending DHCPACK to client 01c4.9ded.0706.aa (192.168.2.41).
*Aug 17 22:03:14.858: DHCPD: no option 125
*Aug 17 22:03:14.858: DHCPD: broadcasting BOOTREPLY to client c49d.ed07.06aa.
*Aug 17 22:03:18.198: DHCPD: client's VPN is .
*Aug 17 22:03:18.198: DHCPD: DHCPDECLINE received from client 01c4.9ded.0706.aa.
*Aug 17 22:03:18.198: DHCPD: removing ARP entry (192.168.2.41 vrf default).
*Aug 17 22:03:18.198: DHCPD: Sending notification of TERMINATION:
*Aug 17 22:03:18.198: DHCPD: address 192.168.2.41 mask 255.255.255.0
*Aug 17 22:03:18.198: DHCPD: reason flags: DECLINE
*Aug 17 22:03:18.198: DHCPD: htype 1 chaddr c49d.ed07.06aa
*Aug 17 22:03:18.202: DHCPD: lease time remaining (secs) = 7196
*Aug 17 22:03:18.202: DHCPD: returned 192.168.2.41 to address pool two.
Advice is greatly received as to what I am doing wrong please?
Cheers, Bill
7 Replies 7
balaji.bandi
change the lease 0 2 to correct config :
lease {days [hours][minutes] | infinite}
some time may be due to bug may happens :
test with below and adjust accordingly - if that works
lease infinite
BB
If the suggestion about changing the lease does not solve the issue perhaps you might provide more details about the configuration of the 1841?
Rick
Hi Richard,
The config is in a post further up...
But, I've changed the IOS to 15.1 (1) T and everything, including DHCP, is working.
I remember saying to a friend 'I thought Cisco didn't do bugs...' and he fell about laughing
I am finding plenty of bugs.
Cheers and thanks for the comments...
Hi again, I seem to have accidentally generated two threads for this topic, hence my reply about the config - which is posted in the other thread. But it is now working, so thanks...
Glad all working - what what the fix, not sure about other thread, i was not part of it.
BB
As simple as using a different version of IOS...
I was using c1841-adventerprisek9-mz.151-3.T2 and it failed - I tried a 12.4 T version and it worked and then I tried c1841-adventerprisek9-mz.151-1.T which also worked!
Cheers!
Thanks for the update. Glad to know that the issue appears to be just an issue with the version of code.
Rick
