concurrent connection in ISDN
lifebook567
In ISDN, will the concurrent connections are limited to the number of B channel we have? Since it can call and maintain one connection at a time for each B channel, what if all of the interfaces are busy and some host want to dial out to another destination? Will the router buffer those interesting packets and dial out when an interface available? Or just drop them? So in ISDN BRI rate which has only 2 B channels can support only 2 destinations at a time? Can I make connections to many destinations using only1 B channel? Ex. use sub interface or multilink like Frame Relay?
spremkumar
Level 9
Level 9
At any point of time with a single isdn line you can have 2 concurrent connections using the B-Channels available with the line.
The 2 connections may be both dial outs or dial ins or a mix of both.
regds
mchoo2005
1. When both B channels are in use, subsequent dial requests to another destination will be dropped.
2. Yes, 2 B-channels can only support up to 2 destinations at one point in time.
3. No, you can't create subinterfaces on ISDN interfaces.
