Conditional Access-List On Cisco 1841 Router
ranjit123
Level 3
Level 3
Dear All,
In Our Network We have a MPLS link as Primary and back-up link as a VSAT.
When MPLS Link goes down traffic automatically shift to VSAT, also our requirement is that once the traffic is shifted to VSAT the access-list configured on the router LAN interface should be removed when the primary link goes down it should be applied again when the primary link comes back again
We Tried the same config with Embedded Event Manager but its not working.
Kindly Update me how can we do the same with some other mehtod.
With Regards,
Ranjit
John Blakley
The only way to automate this would be through EEM. What problems are you having, and can you post your script?
HTH,
John
HTH, John *** Please rate all useful posts ***
Dear All,
After changing the IOS of cisco 1841 router EEM is working fine.
Thanks and Regards,
Ranjit
Hi Ranjit,
Can you post your working config and ios version.
I have similar requirement now.
thanks
