WCCP on Cisco 6500
CSCO11177789
Hi;
I'm a little confused about wccp configuration and redirection . I want to integrate with websense cache proxy. On backbone, appliance connected on gig 5/1 for example....Also i want to redirect all http packet on vlan 10.
What  am i supposed to do under gig and vlan configuration ?
Thanks.
Mohamed Sobair
Level 7
Level 7
Yes , there is no special config for the proxy, a tunnel is created dynamically with all registry information when WCCP configured on the router between the webcache and the router.
Mohamed
Mohamed Sobair
Level 7
Level 7
Here what you need to configure:
1- Enable WCCP globally by configuring ( ip wccp web-cache ) , the default version is 2
2- Redirect Vlan 10 List HTTP request globally with ( ip wccp web-cache redirect-list 100 )
    access-list 100 permit tcp x.x.x.x y.y.y.y any eq www
3- Apply the redirection on the Vlan interface:
    interface vlan10
    ip wccp web-cache redirect in
Mohamed
First of all, thanks for your reply. But i couldnt see any configuration about proxy connection port. I understood there isnt need to?
Best regards
Umut
Mohamed Sobair
Level 7
Level 7
Mohamed
