Conditional default route advertisement in ISIS (IOS XR)
kszarkowicz
I am doing conditional default route advertisement in ISIS on IOS XR as follows:
route-policy PL-DEFAULT-ROUTE-CONDITION
  if rib-has-route in (172.16.10.1/32, 172.16.10.2/32) then
    set level level-1
  endif
end-policy
router isis core
 address-family ipv4 unicast
  default-information originate route-policy PL-DEFAULT-ROUTE-CONDITION
It is working like a charm.
Now, I would like to change my condition, and instead of looking for specific /32 routes, I would like to look for routes with some community attached, so I change my RP to following:
  if community matches-any (65000:1) then
    set level level-1
  endif
end-policy
but with that I get commit error:
RP/0/0/CPU0:02-ABR2(config)#show configuration failed
Tue Jul  8 18:51:27.895 UTC
!! SEMANTIC ERRORS: This configuration was rejected by
!! the system due to semantic errors. The individual
!! errors with each failed configuration command can be
!! found below.
    set level level-1
  endif
end-policy
!!% Policy [PL-DEFAULT-ROUTE-CONDITION] uses the 'community' attribute. There is no 'community' attribute at the isis default-originate attach point.
end
Is there a way to achieve that?
kszarkowicz
Any ideas?
