conf vlan and access internet
Hi all,
Need to conf cisco switch 3560G that is layer 3 switch and cisco router to achive this below
i want all vlan to access an internet
vlan 7 for management that only admin access it
vlan 8 for network devices that is all 3 cisco switch and router
vlan 6 is server vlan to be able to accessed by all vlan
vlan 2,3,4,5 should NOT be able to talk to each other
pls assist by checking my conf and diagram b4 implementation
note all 3 cisco switch will have the same conf
thanks
2 Accepted Solutions
cadet alain
on the router:
1) no need for this command as it is only used when not routing:
ip default-gateway 123.49.42.161
So you can get rid of it:
no ip default-gateway 123.49.42.161
2)your static default route is not correct:
ip route 0.0.0.0 0.0.0.0 123.49.42.162
it should be ip route 0.0.0.0 0.0.0.0 123.49.42.161
So delete your wrong default-route and configure corect one:
no ip route 0.0.0.0 0.0.0.0 123.49.42.162
3)your nat ACL is not permitting your vlan subnets
I suppose you want these to access the internet so you must do this:
no access-list 102
access-list 102 permit 172.17.0.0 0.0.255.255 any
Then you also must define your NAT interfaces like this:
interface G0/1
ip nat inside
interface G0/0
ip nat outside
4) all your static routes are incorrect they must be
ip route 172.17.18.128 255.255.255.192 172.17.18.3
ip route 172.17.18.192 255.255.255.192 172.17.18.3
ip route 172.17.19.192 255.255.255.192 172.17.18.3
ip route 172.17.19.128 255.255.255.192 172.17.18.3
ip route 172.17.18.32 255.255.255.224 172.17.18.3
ip route 172.17.18.16 255.255.255.240 172.17.18.3
ip route 172.17.18.0 255.255.255.240 172.17.18.3
Now let's take care of the switches:
on Core Switch A
1) I wouldn't disable cdp because it is a great troubleshooting tool and you might need it at least before
you know everything is ok
2) you have vlan 5 172.17.129.128 /26 but I don't see a static route on the router for this VLAN, you should add it
3) on the router you have a static route to 172.17.18.0/28 but I don't see any SVI on the switch for it
4)Why ACL VLAN6 and 7 if you permit all but don't log anyting
5)Your ACLs are not configured correctly as were the static routes, you must use the subnet IP not the SVI IP
  so
  -ACL VLAN2: permit 172.17.18.32
  - ACL VLAN4 : same
  -ACL VLAN3: same
  -ACL VLAN5: same
Regards.
Alain.
When you say vlan 8 you mean the routed subnet between the switch and router? if so then it is not considered a VLAN  but just a subnet configured on a switch routed port.So no need to to configure it
For management VLAN yes it must exist on every switch
Concerning the ACLs on VLAN 6 and VLAN 7 don't create ACL  because the other vlans won't communicate with them anyway because of ACLs configured under respective SVIs.
Indeed like proposed above you can also use private vlan config but I've only done this once in the CCNP curriculum and never since so you'll have to wait for someone having played with it more to explain exactly the config.
Regards.
Alain
10 Replies 10
Manouchehr
It's much easier and scable to use private-vlans
What problems do you have now?
pls give the way forwad on that private vlan as u suggest
Thx
cadet alain
on the router:
no access-list 102
interface G0/1
ip nat inside
interface G0/0
ip nat outside
on Core Switch A
  so
  - ACL VLAN4 : same
  -ACL VLAN3: same
  -ACL VLAN5: same
Regards.
Alain.
Allain
Thanks very much for ur quicky respond
its true i can see ,now what i wanted the most is
1. Is the command correct on the switch?take a look at each command pls,should i add vlan 7 (managenent vlan) and vlan 8 (network device vlan-that is switches and router)
//Switch-A int G0/27 is connected to Switch-C int G0/25 with fiber cable
Switch-A(config)# int G0/27
Switch-A(config-if)# switchport mode dynamic desirable
Switch-A(config-if)# switchport mode trunk
Switch-A(config-if)# switchport trunk encapsulation dot1q
Switch-A(config-if)#  switchport trunk allowed vlan remove 1-4096
Switch-A(config-if)# switchport trunk allowed vlan add 2,3,4,5,6,7
2.Vlan 8 is network device vlan,do i suppose to create it on switches?
3.What do u suggest on vlan 6,7,8....to me i wanted vlan 6 to reach all other vlan that is vlan 2,3,4,5
4.what is the best practise on this pls
thanks,
Joseph
Regards.
Alain
Thanks Alain,
All work well regarding ur guidance,
But now all vlan can see each other ,and i would like only vlan 6 to be reached by all other vlan and vlan 2,3,4,5 NOT to see each other.how to do that pls ?
Can u tell me what to do on switch?so that all vlan can share samba file ip of samba 172.17.18.36,right now samba is not accessible?
Post your new config.
Regards.
Alain
Alain,
Switch A -configures as layer 3 switch and has vtp server
switch B and C configured as layer 2 and its all vtp client
all vlan can now browse internet clearly but i wanted
1.vlan 2,3,4,5,6,7 NOT to see each other But vlan 10 can reach all vlan as its management vlan and vlan 8 can be reached by all vlan as its server vlan and vlan 8 can reach all vlan
2.My samba file which belong to server vlan ,can be pinged from all vlan BUT can now be accessed ,i mean their file from samba can not explored
cisco switch conf
cisco-switchA#
no file verify auto
spanning-tree mode pvst
vlan internal allocation policy ascending
interface GigabitEthernet0/1
description connection to ASA
no switchport
ip address 172.17.18.3 255.255.255.240
interface GigabitEthernet0/2
description management vlan
switchport access vlan 10
switchport mode access
interface GigabitEthernet0/3
interface GigabitEthernet0/4
interface GigabitEthernet0/5
interface GigabitEthernet0/6
interface GigabitEthernet0/7
description MIS&security
switchport access vlan 6
interface GigabitEthernet0/8
interface GigabitEthernet0/9
interface GigabitEthernet0/10
switchport access vlan 8
interface GigabitEthernet0/11
interface GigabitEthernet0/12
interface GigabitEthernet0/13
interface GigabitEthernet0/14
interface GigabitEthernet0/15
interface GigabitEthernet0/16
interface GigabitEthernet0/17
interface GigabitEthernet0/18
interface GigabitEthernet0/19
interface GigabitEthernet0/20
interface GigabitEthernet0/21
interface GigabitEthernet0/22
interface GigabitEthernet0/23
interface GigabitEthernet0/24
interface GigabitEthernet0/25
description connection PMU
interface GigabitEthernet0/26
interface GigabitEthernet0/27
description connection MJENGONI
interface GigabitEthernet0/28
interface Vlan1
no ip address
shutdown
interface Vlan2
description 5th and 4th floor
ip address 172.17.18.129 255.255.255.192
interface Vlan3
description 3th floor
ip address 172.17.18.193 255.255.255.192
interface Vlan4
description 2nd floor
ip address 172.17.19.1 255.255.255.192
interface Vlan5
ip address 172.17.19.65 255.255.255.192
interface Vlan6
description MIS and SECURITY
ip address 172.17.19.129 255.255.255.192
ip helper-address 172.17.18.36
interface Vlan7
description PMU
ip address 172.17.19.193 255.255.255.192
interface Vlan8
description server vlan
ip address 172.17.18.33 255.255.255.224
interface Vlan10
ip address 172.17.18.17 255.255.255.240
ip classless
ip route 0.0.0.0 0.0.0.0 172.17.18.1
ip http server
ip access-list extended vlan2
permit ip any 0.0.0.0 255.255.255.224
deny   ip any any
ip access-list extended vlan3
deny   ip any any
ip access-list extended vlan4
deny   ip any any
ip access-list extended vlan5
deny   ip any any
ip access-list extended vlan6
deny   ip any any
ip access-list extended vlan7
deny   ip any any
no cdp run
snmp-server community test123 RO
snmp-server location TEST HQ
snmp-server enable traps snmp authentication linkdo
snmp-server enable traps tty
snmp-server enable traps cluster
snmp-server enable traps entity
snmp-server enable traps cpu threshold
snmp-server enable traps power-ethernet group 1
snmp-server enable traps vtp
snmp-server enable traps vlancreate
snmp-server enable traps vlandelete
snmp-server enable traps flash insertion removal
snmp-server enable traps port-security
snmp-server enable traps envmon fan shutdown supply
snmp-server enable traps mac-notification
snmp-server enable traps config-copy
snmp-server enable traps hsrp
snmp-server enable traps rtr
snmp-server enable traps bridge newroot topologycha
snmp-server enable traps stpx inconsistency root-in
y
snmp-server enable traps syslog
snmp-server enable traps vlan-membership
control-plane
banner motd ^CThis is an official computer system a
ANIZATION. It is for authorized users only. Unautho
sers (authorized or unauthorized) have no explicit
ivacy. Any or
^C
line con 0
line vty 0 4
password 7 071F224F4C765455687898990
login
line vty 5 15
login
end
cisco-switchB#
no aaa new-model
system mtu routing 1500
ip subnet-zero
no file verify auto
description 4th and 5th
switchport access vlan 2
description 3rd floor
switchport access vlan 3
switchport access vlan 4
description 1st floor
switchport access vlan 5
description connection mis switch
switchport trunk allowed vlan 2-8,10
interface Vlan1
no ip address
no ip route-cache
shutdown
interface Vlan2
no ip address
no ip route-cache
interface Vlan3
no ip address
no ip route-cache
interface Vlan4
no ip address
no ip route-cache
interface Vlan5
no ip address
no ip route-cache
interface Vlan6
description mis
no ip address
no ip route-cache
interface Vlan7
description pmu
no ip address
no ip route-cache
interface Vlan8
description server farm
no ip address
no ip route-cache
interface Vlan10
ip address 172.17.18.18 255.255.255.240
no ip route-cache
ip default-gateway 172.17.18.17
ip classless
ip http server
control-plane
line con 0
line vty 0 4
password 7 120906141666666666666778778
login
line vty 5 15
login
end
cisco-switchc#
no aaa new-model
ip subnet-zero
no file verify auto
interface Vlan1
no ip address
no ip route-cache
shutdown
interface Vlan2
no ip address
no ip route-cache
interface Vlan3
no ip address
no ip route-cache
interface Vlan4
no ip address
no ip route-cache
interface Vlan5
no ip address
no ip route-cache
interface Vlan6
description mis
no ip address
no ip route-cache
interface Vlan7
description pmu
no ip address
no ip route-cache
interface Vlan8
no ip address
no ip route-cache
interface Vlan10
ip address 172.17.18.19 255.255.255.240
no ip route-cache
ip classless
ip http server
control-plane
line con 0
line vty 0 4
login
line vty 5 15
login
end
Try below...
interface Vlan6
ip access-group vlan6
interface Vlan2
interface Vlan3
interface Vlan4
interface Vlan5
permit ip any any
deny ip 172.17.18.0 0.0.0.255
permit ip any any
permit ip any any
permit ip any any
permit ip any any
Please rate the helpfull posts.
Naidu.
Naidu
Pls put comment  on each permit and deny so i can get to know what will happen?on vlan 6 by putting
ip access-group vlan6,it just rejecting that command...what will happen to vlan 4 by deny ip
172.17.18.0 0.0.0.255,u mean vlan 4 will also communicate with all vlan since it has 172.17.19.0?
permit ip any any
permit ip any any
permit ip any any
permit ip any any
permit ip any any
thanks
