Config BGP add NEW ISP with dual AS IIX and INP
robmabayu
Hi master.
I have router ASR9K with single ISP (ISP-A) using BGP routing.
now, my company need to add new ISP (ISP-B) on Router.
The ISP-B carry single ip neigbor (peering) with dual AS,
for example AS-300 for Internasional (IIX) and AS-400 for (INP).
how about config single multihoming on my Router ASR9K ?
I'm create the plan config with using wieght for traffic outbound and as-path prepend of inboud traffic.
I attach topology plan
this is my config.
Current:
1.prefix-list-Current
prefix-set NETWORK
192.168.10.0/24
192.168.20.0/24
end-set
prefix-set IPV4_BLOCK
10.10.0.0/16 le 32,
172.16.0.0/12 le 32,
end-set
2. Route-Policy-Current
route-policy PREFIX_OUT
if destination in NETWORK then
pass
endif
end-policy
route-policy RP_INBOUND
apply RPL_DENY_IPV4_BOGONS
end-policy
route-policy RP_DENY_IPV4_BLOCK
if destination in IPV4_BLOCK then
drop
else
pass
endif
end-policy
3.  BGP Config - Current
router bgp 100
bgp router-id 1.1.1.1
address-family ipv4 unicast
network 192.168.10.0/24
network 192.168.20.0/24
neighbor 1.1.1.2
remote-as 200
route-policy RP_INBOUND in
route-policy PREFIX_OUT out
soft-reconfiguration inbound always
neighbor 2.2.2.1
remote-as 200
route-policy RPL_INBOUND in
4. Route Static - Current router static
192.168.10.0/24 Null0
192.168.20.0/24 192.168.10.130
5. add attribute weight on existing BGP (ISP-A)
router bgp 100
neighbor 1.1.1.2
remote-as 200
weight 80  (add attribute weight on BGP ISP-A)
6. Create Route-Policy for ISP-B (new)
route-policy PREFIX_NETWORK_PREPEND_ISP-B
prepend as-path 100 100
pass
else
drop
endif
end-policy
commit
7. add on BGP Config for New ISP-B
neighbor 3.3.3.2
remote-as 300
description INP-ISP-B
weight 60
route-policy PREFIX_OFFICIAL_PREPEND_INDOSAT out
neighbor 3.3.3.2
remote-as 400
description INIX-ISP-B
weight 60
route-policy PREFIX_NETWORK_PREPEND_ISP-B out
commit
could you verify plan my config, is true or false, please give me suggestion
thanks
ubay
Giuseppe Larosa
Hello @robmabayu ,
I don't think the proposed setup will work because neighbor 3.3.3.2 belongs to a single AS either AS300 or AS 400.
You will likely need to use two subinterfaces with different IP subnets
3.3.3.2 remote-as 300
3.3.3.6 remote-as 400
All the rest may work once this is fixed
Hope to help
Giuseppe
Giuseppe Larosa
Hello @robmabayu ,
Hope to help
Giuseppe
