Config Zone-based policy firewall
tungnf1
Hi im new to networking and struggle with some of my assesment,
So i follow instruction but still could not
ping
the server at all, i have try ACL but same result. My cofig
Current configuration : 2172 bytes
! Last configuration change at 23:44:08 UTC Wed Sep 13 2023
! NVRAM config last updated at 23:38:21 UTC Wed Sep 13 2023
version 15.1
hostname Rx
boot-start-marker
boot-end-marker
enable secret X.X.X
no aaa new-model
no ipv6 cef
ip source-route
ip cef
ip dhcp pool LAB
network 192.168.5.0 255.255.255.0
default-router 192.168.5.1
license udi pid CISCO1941/K9 sn FGL163212NZ
license boot module c1900 technology-package securityk9
username admin privilege 15 secret X.X.X
redundancy
class-map type inspect match-any ToINTERNET_MAP
match protocol http
match protocol ssh
match protocol telnet
policy-map type inspect ToINTERNET_POLICY
class type inspect ToINTERNET_MAP
inspect
class class-default
drop
zone security INSIDE
zone security INTERNET
zone-pair security INOUT source INSIDE destination INTERNET
service-policy type inspect ToINTERNET_POLICY
interface Embedded-Service-Engine0/0
no ip address
shutdown
interface GigabitEthernet0/0
ip address 192.168.254.5 255.255.255.0
zone-member security INTERNET
duplex auto
speed auto
interface GigabitEthernet0/1
ip address 192.168.5.1 255.255.255.0
zone-member security INSIDE
duplex auto
speed auto
interface Serial0/0/0
no ip address
shutdown
clock rate 2000000
interface Serial0/0/1
no ip address
shutdown
clock rate 2000000
ip forward-protocol nd
no ip http server
no ip http secure-server
ip route 0.0.0.0 0.0.0.0 GigabitEthernet0/0
control-plane
line con 0
password X.X.X
login
line aux 0
line 2
no activation-character
no exec
transport preferred none
transport input all
transport output pad telnet rlogin lapb-ta mop udptn v120 ssh
stopbits 1
line vty 0 4
password X.X.X
login
transport input all
scheduler allocate 20000 1000
end
Much appreciated
2 Accepted Solutions
M02@rt37
hello @tungnf1,
Add protocol icmp:
match protocol http
match protocol ssh
match protocol icmp
Best regards
Can You Confirm this issue is solved?
5 Replies 5
M02@rt37
hello @tungnf1,
Add protocol icmp:
match protocol http
match protocol ssh
match protocol icmp
Best regards
awesome, it works now thank you !!!
You're very welcome @tungnf1
Best regards
Yep , the solution works perfect
