PPP CHAP OSPF
November 123
1. PPP & CHAP
- R4 must require R1 and R2 to authenticate using CHAP but R1 and R2 must not require R4 to authenticate
means that you can't run command
ppp authentication chap
command on R1 and R2 and you cant use
Username command on R1 and R2 otherwise it ask asuthentication from R4.
- R1 and R2 cannot use ppp chap hostname,
they can use ppp chap password with
"Security".
- Make sure that all CHAP passwords are shown in clear int the configuration - Use radius server at 6.6.44.200 as authentication server and fallback to the local AAA database in case the server is unreachable.
- Use "Singtel" as key required by the
Radius server
- Make sure AAA authentication does not affect any console or line VTY from any PPP devices (ensure that there is no username
prompt either) - Use only default authentication list for both console and line VTY.
Hello
@November 123 wrote:
 PPP & CHAP
Hello
one way PPP authentication is applicable?
Examaple:
R4
username Router1 password STAN1
username Router2 password STAN2
int y/y
Description R1
encapsulation ppp
ppp authentication chap callin  < one way authentication>
ppp chap hostname Router1
int x/x
Description R2
encapsulation ppp
ppp chap hostname Router2
R1 & R2
username Router4 password STAN4
int x/x
encapsulation ppp
ppp chap hostname Router4
"Security".
Radius server
radius server STAN
address ipv4 6.6.44.200 auth-port 1645 acct-port 1646
key Singtel
aaa group server radius RadiusPAP
server name STAN
aaa new-model
aaa authentication login default group RadiusPAP local
aaa authentication ppp default group RadiusPAP local
aaa authorization exec default group RadiusPAP if-authenticated
Kind Regards
Paul
I dont get what issue here ?
Hello
 PPP & CHAP
Hello
Examaple:
R4
int y/y
Description R1
encapsulation ppp
int x/x
Description R2
encapsulation ppp
R1 & R2
int x/x
encapsulation ppp
"Security".
Radius server
radius server STAN
key Singtel
server name STAN
aaa new-model
Kind Regards
Paul
i have do Command
#enable
#config t
#radius server Stan
its show that invalid marker plz help me
you first need to enable AAA
aaa new-model
then you can use radius server command
