Configurate the 1760 Router
ray.ng
Hi all, I am working to config a Cisco 1760 router. Due to the router just have one ethernet interface. But I have two subnet on the network. So I config a ethernet interface as two IP address. look like as:
interface Fastethernet0/0
ip address 148.164.234.251 255.255.255.0 secondary
ip address 172.25.103.251 255.255.252.0
ip helper-address 148.164.234.152
The DHCP server is 148.164.234.152 and it have a scope to assign the IP to 172.25.103.0 network. But the client cannot get the IP on 172.25.103.0 subnet form the DHCP server after I set it up. How can I fix it on the router?
mirco.orlandi
If you have a "good" switch on lan, use dot1q between router and switch and play with 2 vlan.
interface FastEthernet0/0
interface FastEthernet0/0.2
  encapsulation dot1Q 2
On switch use vlan1 as native (is default). Create vlan2 and assign ports.
Mirco.
mirco.orlandi
Mirco.
