1-way audio problem
winston123
hi guys, I have 1-way audio..far end can't hear me....connection: US to UK, over public ip.....my end/US..cisco 2811....>cisco switch2900...>FW(ASA)...>internet, codec g711ulaw on both ends...UK side:internet....>soft switch (Veraz)...any ideas what may be causing this 1-way audio problem...I have a simple config on my 2811, no QoS/CoS yet........
The farend told me today that they do not see that we are sending rtp msgs...
Thanks in Advance,
Winston,
12 Replies 12
Rick Morris
Level 6
Level 6
Have you tried changing the codec to g729, 711 requires a lot of overhead and bandwidth and typically run onnet in the office. I assume this is CME?
Is it between offices or between specific devices? Periodic?
I have not tried that yet, I will try....it is between offices..network setup...voice server (with dialogic t1 card)---->2811--->cisco 2900--->FW (ASA--->internet...
The farend is saying I am not sending rtp packet/msg..
note: I have the 2811 bandwidth for myself.it is just one test call i place over it.
thx
So the call set's up, rings the far end, the far end goes off hook, but no audio? This may be a stupid question, but are they answering via headset, speakerphone, or handset? Do you know that you have a known good phone?
yes they pickup the phone (a desk phone)no speaker or headset)and say hello, i hear them,but when I hello back to them they do not hear me.
is this system wide or just one phone from your end?
Meaning have you tried more than one phone
it is wide..have tried other phone set and other phone #'s...
How about the farend telling me they do not see I am sending rtp packets/msgs
thx
system wide issue, I need to think about this a little more.
can you post the telephony service config as well as the mgcp config?
voice server--->2811--->switch----fw--->internet.
2811_UK-VOIP#sh run | s dial-peer
dial-peer voice 10 pots
incoming called-number .
direct-inward-dial
port 0/1/0:23
dial-peer voice 100 voip
destination-pattern .
progress_ind setup enable 3
session target ipv4:x.x.x.x
dtmf-relay rtp-nte h245-signal h245-alphanumeric
codec g711ulaw
no vad
2811_UK-VOIP#
2811_UK-VOIP#sh ip ro
Gateway of last resort is 192.x.x.x to network 0.0.0.0
C 192.x.x.x/24 is directly connected, FastEthernet0/0
S* 0.0.0.0/0 [1/0] via 192.x.x.x
2811_UK-VOIP#..
no acl/no qos/cos
Thanks, I was able to figure out...it was an acl applied to fa0/0 causing the issues...thx for all your help
what did the ACL look like you had appiled?
That never crossed my mind to check.
It's usually a firewall (or ACL) or a double NAT when you get one way voice.
Something like this access-list 100 permit ip 192.0.0.0 0.255.255.255 host 192.x.x.x(going to fa0/0)...that seemed to be dropping rtp/udp packets
thx
