Configuration Help 891 Router
DEENA VERAPPAN
Hi All,
Hoping I can get some help, or advice on a configuring an 891F ISR, as a router on a stick. I am unable to configure the switch ports to act as a trunk. The port takes trunk configuration commands, i.e
switchport mode trunk
switchport trunjk encap dot1q
switchport trunk native vlan 11
however I can't specify the vlans to allow across the trunk.
I tried to create subinterfaces on the the switch ports, ports 0 - 7, will not allow it. I am able to create the subinterfaces on the WAN port(8), but I can't enable routing on the switch ports. Command, no switchport, is not accepted on the switch ports.
Any ideas, suggestion??
Cheers
Deena
https://supportforums.cisco.com/document/62176/configuration-example-861w881w891w-series-isrs
