Configuration issue with IPsec
Daniel Slyk
Level 8
Level 8
Hi all,
 I am having a hard time with IPSec config, I set it up and when I enter the command on the tunnel interface, tunnel goes down right away.
This is the error message :
 %CRYPTO-6-ISAKMP_ON_OFF: ISAKMP is ON
 LINEPROTO-5-UPDOWN: Line protocol on Interface NVI0, changed state to up
LINEPROTO-5-UPDOWN: Line protocol on Interface Tunnel212, changed state to downDUAL-5-NBRCHANGE: EIGRP-IPv4 100: Neighbor 10.212.212.2 (Tunnel212) is down: interface down
CRYPTO-4-RECVD_PKT_NOT_IPSEC: Rec'd packet not an IPSEC packet. (ip) vrf/dest_addr= /12.0.0.1, src_addr= 12.0.0.2, prot= 47
This happens on both routers.
Here is the config from both routers.
R1 :
crypto isakmp policy 10
encr aes 256
hash sha256
authentication pre-share
group 14
lifetime 3600
crypto isakmp key cisco123 hostname R2
crypto ipsec transform-set R1-VPN esp-aes 256 esp-sha256-hmac
mode transport
crypto ipsec profile R1PROFILE
set transform-set R1-VPN
interface Tunnel212
ip address 10.212.212.1 255.255.255.252
tunnel source GigabitEthernet0/0
tunnel destination 12.0.0.2
tunnel protection ipsec profile R1PROFILE
R2 :
crypto isakmp key cisco123 hostname R1
crypto ipsec transform-set R2-VPN esp-aes 256 esp-sha256-hmac
mode transport
crypto ipsec profile R2PROFILE
set transform-set R2-VPN
interface Tunnel212
ip address 10.212.212.2 255.255.255.252
tunnel destination 12.0.0.1
tunnel protection ipsec profile R2PROFILE
interface Tunnel223
ip address 10.223.223.1 255.255.255.252
tunnel source GigabitEthernet0/1
tunnel destination 23.0.0.2
I have been looking for the solution for a while, so forgive me if this was already asked some place.
Thank you so much.
Daniel.
Thanks for posting the configs. The main issue that I see is that on R2 the tunnel connecting to R1 does not include the statement
That is configured on a different tunnel Tunnel223. Add the tunnel protection to tunnel Tunnel212 and let us know if the behavior changes.
Rick
9 Replies 9
Georg Pauwen
you posted partial configs, so we cannot really see what is going on. Can you post the full configs (sh run) of both routers ?
Make sure you are just advertising the tunnel and LAN subnets in your EIGRP, not the WAN subnets:
R1
router eigrp 100
network 10.212.212.0 0.0.0.3
network x.x.x.x y.y.y.y <-- your LAN
R2
router eigrp 100
Hi Georg, my bad.
Here is the full config :
R2
Current configuration : 3219 bytes
version 15.9
hostname 2
boot-start-marker
boot-end-marker
no aaa new-model
mmi polling-interval 60
no mmi auto-configure
no mmi pvc
mmi snmp-timeout 180
--More--
ip cef
no ipv6 cef
redundancy
interface Tunnel212
interface Tunnel223
interface GigabitEthernet0/0
ip address 12.0.0.2 255.255.255.252
duplex auto
speed auto
media-type rj45
interface GigabitEthernet0/1
ip address 23.0.0.1 255.255.255.252
duplex auto
speed auto
media-type rj45
interface GigabitEthernet0/2
no ip address
shutdown
duplex auto
speed auto
media-type rj45
interface GigabitEthernet0/3
no ip address
shutdown
duplex auto
speed auto
media-type rj45
router eigrp 100
network 10.223.223.0 0.0.0.3
ip forward-protocol nd
no ip http server
no ip http secure-server
ipv6 ioam timestamp
control-plane
banner exec ^C
R1
Current configuration : 3052 bytes
version 15.9
hostname R1
boot-start-marker
boot-end-marker
no aaa new-model
no mmi pvc
ip cef
no ipv6 cef
redundancy
interface Tunnel212
ip address 12.0.0.1 255.255.255.252
duplex auto
speed auto
media-type rj45
no ip address
shutdown
duplex auto
speed auto
media-type rj45
no ip address
shutdown
duplex auto
speed auto
media-type rj45
no ip address
shutdown
duplex auto
speed auto
media-type rj45
router eigrp 100
no ip http server
ipv6 ioam timestamp
control-plane
banner exec ^C
In this topology I have a third router also, but I am focusing o the first tunnel that is not working.
Thank you for your help.
the configurations you posted are different from what you posted originally. There is no VTI anymore ?
You are right, my VM restarted and my config wasnt saved. I did the configuration again and same issue obviously :).
Here is the config again, thank you.
R1
Current configuration : 3435 bytes
! Last configuration change at 22:44:35 UTC Wed Oct 27 2021
version 15.9
hostname R1
boot-start-marker
boot-end-marker
no aaa new-model
no mmi pvc
ip cef
no ipv6 cef
redundancy
encr aes
hash sha256
group 14
lifetime 3600
mode transport
interface Tunnel212
duplex auto
speed auto
media-type rj45
no ip address
shutdown
duplex auto
speed auto
media-type rj45
no ip address
shutdown
duplex auto
speed auto
media-type rj45
no ip address
shutdown
duplex auto
speed auto
media-type rj45
router eigrp 100
no ip http server
ipv6 ioam timestamp
control-plane
banner exec ^C
R2
Current configuration : 3545 bytes
version 15.9
hostname R2
boot-start-marker
boot-end-marker
no aaa new-model
no mmi pvc
ip cef
no ipv6 cef
redundancy
crypto isakmp policy 20
encr aes 256
hash sha256
group 14
lifetime 3600
mode transport
interface Tunnel212
interface Tunnel223
duplex auto
speed auto
media-type rj45
duplex auto
speed auto
media-type rj45
no ip address
shutdown
duplex auto
speed auto
media-type rj45
no ip address
shutdown
duplex auto
speed auto
media-type rj45
router eigrp 100
no ip http server
ipv6 ioam timestamp
control-plane
banner exec ^C
Here are the messages I am getting :
%LINEPROTO-5-UPDOWN: Line protocol on Interface Tunnel212, changed state to down
%DUAL-5-NBRCHANGE: EIGRP-IPv4 100: Neighbor 10.212.212.2 (Tunnel212) is down: interface down
%LINEPROTO-5-UPDOWN: Line protocol on Interface NVI0, changed state to up
%CRYPTO-4-RECVD_PKT_NOT_IPSEC: Rec'd packet not an IPSEC packet. (ip) vrf/dest_addr= /12.0.0.1, src_addr= 12.0.0.2, prot= 47
Rick
Silly mistake of mine, thank you for your help. Much appreciated.
Daniel.
Daniel
You are welcome. It is an easy mistake to make. But sometimes difficult to see in your own work (sometimes we see what we expect to see rather than what is actually in the config) and frequently easier for a fresh pair of eyes to see. This is one of the great things about this community. Thank you for marking this question as solved. This will help other participants in the community to identify discussions which have helpful information. This community is an excellent place to ask questions and to learn about networking. I hope to see you continue to be active in the community.
Rick
Daniel
@Georg Pauwen makes a good point about the possibility that this is an issue with recursive routing (when the routing logic says that the way to get to the tunnel end point is to go through the tunnel). With recursive routing there are usually some other log messages. Are there other messages generated in the log at about this time?
Rick
All is working now.
Daniel.
