Configuration Lock - Class ROLLBACK
aformisani
I got a problem with a catalyst 4503 regarding the configuration lock.
Now I can enter in configure terminal but I cannot configure anything.
If I try to set something in configuration I will receive this output:
Configuration mode locked exclusively by user 'unknown' process '18' from terminal '0'. Please try later.
Nobody except me is logged in and also if I log out and then log in again, the problem is not solved.
The process ID 18 is:
18 ME  1070173C        6024      2187    2754 32356/38000   0 Policy Manager
The "show configuration lock" give me the following output:
Parser Configure Lock
Owner PID                        : 18
User                             : unknown
TTY                              : 0
Type                             : EXCLUSIVE
State                            : LOCKED
Class                            : ROLLBACK
Count                            : 1
Pending Requests                 : 0
User debug info                  : Rollback
Session idle state               : TRUE
No of exec cmds getting executed : 0
No of exec cmds blocked          : 0
Config wait for show completion  : FALSE
Remote ip address                : Unknown
Lock active time (in Sec)        : 22082
Lock Expiration timer (in Sec)   : 600
So it seems that the cause is the roolback. But I don't have any rollback active:
show archive config rollback timer
%No Rollback Confirmed Change pending
Someone knows how to unlock the configuration?
Kscroggins77
Looking for a solution to this same issue.
Cisco documentation I found does not apply to my IOS version.
http://www.google.com/url?sa=t&rct=j&q=&esrc=s&source=web&cd=1&cad=rja&uact=8&ved=0CB4QFjAA&url=http%3A%2F%2Fwww.cisco.com%2Fc%2Fen%2Fus%2Ftd%2Fdocs%2Fios%2Ffundamentals%2Fcommand%2Freference%2Fcf_book%2Fcf_c1.html&ei=Rq4AVbbLIoaZgwS7wICwDA&usg=AFQjCNE9Sb8e_8g-YqomjzuD4dSOw4_aZg&bvm=bv.87920726,d.eXY
