Configuration not saving in 1841
majed.balsharaf
I'm having 1841 Router, its configuration is not getting safed. If I reboot the router all my running-config is like default. But when I check my
sh startup all the configuration which I did is displayed.   Checked the config-registery too and its 0x2142 changed too 0x2102 still the same problem, when reloading the router all the running config is disappeared.
Raju Sekharan
Check if you are able to open the startup-config from the nvram
commad: more nvram:startup-config
Sandeep Choudhary
HI Majed,
You need to change the config register.
The routers were left in password recovery  mode of 0x2142.  Changing it to the proper 0x2102 fixed this mess.  I  hope this will save others who come across this problem.
Do this: en conf t config-register 0x2102
http://www.cisco.com/en/US/products/hw/routers/ps233/products_tech_note09186a00800a65a5.shtml
Hope it helps.
please rate if it helps.
Thanks for solution
Hello
post the output to
show boot
res
paul
Kind Regards
Paul
